11-07-2007, 01:39 PM | #1 |
Clutch Rod Hole Plug
I can't find a source for a firewall plug for the clutch rod hole. Does anyone have a suggestion?
Tom
'69 swb stepside in progress. '59 Corvette lifetime project Last edited by basketcase; 11-07-2007 at 01:39 PM. |
11-07-2007, 01:42 PM | #2 |
Re: Clutch Rod Hole Plug
I plan to just weld mine up and paint it...
All Toys: 1971 C10 Fleetside - I needed it! 1970 C10 Stepside - Midlife Crisis 1969 C20 3/4 Longbed - Beast! 1966 Mustang Fastback - Daily Fun 1965 Mustang Fastback - Money pit! |
11-07-2007, 01:58 PM | #3 |
www.kennystrucks.com
kenny has re-popped and he might have some originals laying around.. |
11-07-2007, 02:07 PM | #4 |
That would have been a good way to go but I'm a little past that point already. Also I want to keep my options open for a 5 speed later on.
Tom
'69 swb stepside in progress. '59 Corvette lifetime project Last edited by basketcase; 11-07-2007 at 02:09 PM. |
11-07-2007, 02:20 PM | #5 |
Thanks for the link to Kenny's. They seem to be having a server problem so I'll try again later of just call them.
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
11-07-2007, 04:55 PM | #6 |
The fram fuel filter looks good on the head, but I would worry about it getting hot.
11-07-2007, 05:01 PM | #7 |
i tried to go to his kenny's web site the other day. i figured it would be fixed by now!!!! i know he has some. if you make a wtb post in the parts board someone might have one available. they sale for $5-10. i had one but gave it to shaneschevys for his panel truck project..
11-07-2007, 05:18 PM | #8 |
On the fast track to nowhere..
If you subscribe to the board you can post a WTB in the classifieds, I'm sure someone will have one. It's 25.00 you won't regret spending!
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
11-07-2007, 06:15 PM | #9 |
Who's got steelies?
I've seen the plugs that Kenney's sells. If I recall correctly, they were a metal bolt on affair. Seem like I saw a plastic plug similar to the grommets used in the other firewall openings that snaps in on a '71 GMC at my local salvage yard.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
11-07-2007, 06:16 PM | #10 |
Official Site Guitar Shredder
Hey basket case what headers are those.....?
11-07-2007, 09:26 PM | #11 |
Watch out for your cornhole !
The original ones did indeed bolt on. It's a metal plate with rubber gasket on the backside.
11-08-2007, 12:02 AM | #12 |
If You Have A Friend With One, You Can Trace And Cut It Out. It Bolts To The Firewall
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
11-13-2007, 01:46 PM | #13 |
I guess I thought it was a plastic push in plug too. Since It's a bolt in I can make one out of some aluminum plate I have laying around. The same stuff I used for the heat shield in the back of my fuel filter in the above photo. Thanks everyone for your help.
The headers are original 1981 Corvette stainless manifolds. I removed the bolt on stamped heat shields and cut off the AIR tubes. Then I welded in the holes and coated them with Eastwood's stailess header coating. Corvettes used similar manifolds up through the 80s and 90s until the LS1 engines came out in '97. Most are 2 1/2" outlet but the '81s are 2". They are cheap to buy used at swap meets and make a cheap stainless header if you don't mind spending some manual labor time on them. Tom
11-13-2007, 02:01 PM | #14 |
its all about the +6 inches
I've been told that 67 - 69 were plastic plugs, and the later ones were the metal plate.
11-13-2007, 02:22 PM | #15 |
I go along with that since there are no screw holes around the big hole.
11-13-2007, 03:33 PM | #16 |
I have a 70 cab that HAD a plastic one. My son seemed to think the only way to get it out was in pieces.
11-13-2007, 05:26 PM | #17 |
excuse me... I couldn't remember if he said 67 - 69, or 67 - 70.
11-13-2007, 06:18 PM | #18 |
That's how I got one...there is a few of the members have them and will sell you one.
Alex 1971 Lil' Red 350 SBC 700R4 |
11-17-2007, 05:50 PM | #19 |
Who's got steelies?
That interesting. I've never seen any A/T trucks in yards around here that had the mounting screw holes. Maybe it varied by factory?
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel Last edited by oldgold70c10; 11-17-2007 at 05:51 PM. Reason: add |
11-17-2007, 11:52 PM | #20 |
My 70 doesn't have any bolt holes where the cover should have been installed, so it is my belief that there was a plastic option at one time. I was going to try to take a clutch boot, and "install" some sort of cover inside it to plug my hole without having to bolt anything on. Some of the new cars use large plastic plugs/clips with a washer looking side to them. I thought you could use one of those installed in a clutch boot to seal up the hole.
"Green Monster" (Red Sox fan) 1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension |
11-18-2007, 03:36 AM | #21 |
67-70 had a plastic plug. I have a couple. Not for sale. But my view is that the heat from the manifold warped them and they just fell out. The plug only came in grey.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
11-18-2007, 04:36 AM | #22 |
That is exactly what I had thought they were. I should get around to fabbing something this weekend.
Tom |
11-18-2007, 11:58 AM | #23 |
Questionable
I have both a rubber piece that I picked up from GMC Paul's, and I recently acquired a section of firewall that indeed has the metal bolt-on affair. The metal bolt-on is simply a lemon-shaped piece of metal with holes in either end and some kind of foam stuff on the side that faces inside of the cab.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
11-18-2007, 12:12 PM | #24 |
70 C/10-Work in progress
my 70 has the metal cover, I wonder if they changed mid-year??
In the garage 1999 Dodge Dakota Sport-Daily Driver 1972 Chevy K/5 CST AC/PS/PB/4x4/Tow Hooks/Tilt 1970 Chevy C/10-Current project |
11-18-2007, 01:25 PM | #25 |
Mine is chrome and has 2 screws that hold it
