Old 11-07-2007, 01:43 PM   #1
steverino66
83 column to 66 wiring?
Okay, guys, tried the electrical area with no luck, hoping someone here has done this recently:
I'm wiring an 83 C10 tilt column I've put into my 66 project (still using its 66 factory wiring on the firewall and front end). I want to use the column ignition switch/neutral safety and turn signal on the 83 column.
I have a wiring diagram for the 66 but can only guess about the 83 wiring coming from the column - it's still attached to its fuse box, also pulled from the donor truck.
I'm not completely rewiring the truck right now, I'll someday get a new complete harness, but any help/suggestions on putting these wires together would be greatly appreciated.
steverino66 is offline   Reply With Quote
