11-07-2007, 05:49 PM | #1 |
need help with block ID
i need some help ID ind teh block in my truck
teh pad in front of the head reads: 1mo527 6vp the casting numbers are 10066036.. i was having trouble reading teh casting some of teh sixes may have been eights i do know its from an 80s truck cause the dip stick is on the pass side thanks josh |
11-07-2007, 10:08 PM | #2 |
Re: need help with block ID
anyone
11-07-2007, 10:50 PM | #3 |
Roadtrip!
The casting numbers don't jive in my book...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
11-07-2007, 10:51 PM | #4 |
Well heres the site I use to decode engine blocks, but I don't see anything like that.
http://www.nastyz28.com/sbchevy/sblock.html Evan
70 Blazer 4x4 305/sm465/np205 80 Buick LeSabre Limited 72 Honda CB350F 77 Honda Cb750K 00 Ducati Monster M900ie |
11-08-2007, 06:00 AM | #5 |
10066036 350 86-up 205HP Car & Truck 2 & 4-bolt Passenger stick 1-piece seal
'71 Custom/10 Deluxe LWB '71 Custom/30 Deluxe Dually |
11-08-2007, 07:36 AM | #6 |
Oh..never mind....
I came up with it as a crate motor. It should have a 2 piece rear seal if that is that case. Here is the information that I found for the number in front of the right head.
Target Master/Goodwrench crate motors will have a serial number something like "1M1234VB" or "1MO1234VP" or even "2M1234VB" or something along those lines. It is only a serial number. There is no way to decode the horsepower of the engine. The casting number shows as: 10066036 350 2/4(bolt) Target Master/Goodwrench crate motor, 2-piece rear seal, "Hecho en Mexico" Here is a link to the site that I found it on. It is the best one that I have found so far. You have to dig through it quite a bit at times, but most of the codes can be found if you look for a while. LINK
1972 Blazer -6 inch lift -35 inch BFG A/T's Turbo 350 NP-205 454 BB (for now) MORE TO COME !!!!!! Now going to 2WD!!!!! Sold. I got it back after 22 years and did not even know it !!! THE STORY HERE Project Low Down Dirty Rat Last edited by ABLAZN; 11-08-2007 at 07:37 AM. |
11-08-2007, 10:52 PM | #7 |
thanks yall i appreciate it
