Old 11-07-2007, 07:18 PM   #1
kris's66lwb
resident wrencher
Red face tach problems
prob is that my tach dosnt work it has the wires but arnt pluged in wher do they go
kris's66lwb is offline   Reply With Quote
Old 11-07-2007, 09:31 PM   #2
04Xrider
Registered thread killer
04Xrider's Avatar
Re: tach problems
Depending on your ignition system, one wire would go to ground, and one to either the coil (-), or distributor if the coil is part of the distributor, if your coil is integrated into the dist, they usually have a dedicated tach prong marked (tach) . and if you have a light, one would go to a switch activated wire when you turn your lights on.
!966 stepside, 350 SB, ZZ-4 roller, Crane roller rockers, 0.030 flat tops, airgap intake, 750 Holley, stainless steel headers, edelbrock SDT mufflers, Mark 8 elec fan, 700R-4, column shift
04Xrider is offline   Reply With Quote
Old 11-08-2007, 06:14 PM   #3
kris's66lwb
resident wrencher
Re: tach problems
its a stock points and condenser
