6-Speed Conversions?
I was just talking to someone about 6-Speed Conversions and wondering if anyone out there knows of any kits available for our '67 to '72 trucks.
I have a '72 C-10, 307, 3-Speed. Not sure I want to convert to one, but I am interested enough in one to read up on them and to consider what the cost would be. Any info would be appreciated. |
![]() Join Date: Dec 2001
Re: 6-Speed Conversions?
crazylonghorn has a Richmond 6 speed in his truck, hopefully he'll chime in here.
I am planning on a Tremec 5 speed swap myself, classicchevy5speed has really complete kits available.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
Thanks,
I checked out ClassicChevy5Speed and that TKO-500 looks pretty good. But are there any complete kits out there to install one if I already have my own trans? |
Fabricate till you "puke"
There a couple shots of the Richmond http://community.webshots.com/user/hotrodhorn pretty straight foward bolt in, but the shifter is a long way back for a bench seat....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
i figured it out one time,
if my memory serves me, its about 4 grand to swap out to a richmond 6 speed, all from summit racing.
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
#6 | |
Contact Keisler Engineering they should be able to hook you right up, if you want any further information I swapped a t-56 into my '67.
1967 C10, Short & Wide with LS1 & T56. |
Truck and auto performance nut
thats the plan for mine, carb'd LSX with a T56
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
I put an ROD 6 speed in a 59 'Vette. Custom trans crossmember and driveshaft shortened 3" or so from Muncie 4 speed. Then 3 of us spent a day working on moving the Long shifter forward, and we got 7/8" out of it. I had to trim the body a tad for the shifter, but the hole in the console was just big enough. All the stock clutch and bellhousing stuff worked fine. No kit was available,and I think with the shifter he was $3600 into parts. Besides the shifter, it was a pretty easy fab job.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() |
PLEASE make a build page when you do it. Im already drooling ![]()
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
well heres something to hold you
#12 | |
Questionable
Pics are always appreciated ![]()
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#13 |
im looking into it a bit...
does a richmond 6 speed fit into the automatics transmission tunnel? or is there ALOT of cutting needed?
#14 |
Guys come on, get u a used t56 and save some money.
#15 | |
#16 |
#17 |
Parts and more parts
Do you have the part numbers and info from your install? I have a 68 C-10 that I would like to do a six speed mod, vice the 4L60E that came with the LS-1 motor that I have to put in it. The seats and the driveline are no problem here.
#18 |
That is nasty, my friend. Seriously. Nasty. Sick nasty, even. is the LS1 stock except for that intake?
#19 |
Questionable
Some that come to mind are: Corvette, Camaro, Firebird, Viper, GTO, Mustang, Cobra, etc. There may be more. Both Borg-Warner and Tremec make a T56, and you will see there is the TKO also, which may or may not be related.
#20 | |
I have a ROD I am thinking about swapping out the T350 for. thanks....
"I feel the need for speed!"... as soon as I am done with my nap. |
#21 |
Thats a LS 364, which is the LS2 that GM offers with the manifold in a crate. Dealer gave me a price where I couldn't justify stroking my 350. Of course I spent it all again on the tranny but it makes me happy
![]() Now if only ECE would get those sandersons made |
#22 | |
#23 |
Junior Member
#24 |
#25 |
Now I'm drooling!
![]() The LS 364/440 w/MSD ignition was what I had originally planned on for mine, but then decided I wanted to go with the LSX block. Its iron so it can be bored conventionally, has 6bolt mains, accepts all LS1/LS2/LS6/LS7/L92 parts(including 6 bolt heads), bore x stroke goes up to something like 511ci, and it can handle up to 2500hp...which is a lot more then mine will be putting out. .....unless there are more deals on the LS 364/440 that can't be ignored!??? oh...and yes, I'll have a build thread! I haven't bothered with it for phase I...which was to strip down my '72 and my '68, and install my '68's body on the '72. Now I can strip down the rest of the '68 chassis, get it powder coated, and begin the build. In the end it will be all new as this truck will be mine for many, many, MANY years to come.
