Old 11-08-2007, 01:30 PM   #1
1969k10stepside
Lift kit install #2
My new lift kit from Rough Country arrived today.As some,or most might know,the front springs they originally sent me weren't arched enough for a 4" lift so they sent some new ones for free.So,with the afternoon free I've got time to get this new lift installed...See y'all later.Here is the pic of the new springs,they are arched right.Hopefully I'll have some after pics later this afternoon.It shouldn't take long,the bolts are all new.
1969k10stepside is offline   Reply With Quote
Old 11-08-2007, 02:24 PM   #2
1969k10stepside
Re: Lift kit install #2
Old springs are out..now time to get the new ones in.I did have to remove my headers though,to get the back bolts out.One reason I'm going back to manifolds.
Old 11-08-2007, 02:35 PM   #3
1969k10stepside
Well....I'll start off with this smilely
The very intellegent people from Rough Country sent me front springs for a 73-87... I wondered why the front springs were hitting the frame in the back and then I checked the numbers...back these go..and now the truck doesn't have a front suspension...Idiots.
Old 11-08-2007, 06:51 PM   #4
va_tlc
va_tlc's Avatar
dang man that sucks.....
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 11-08-2007, 06:54 PM   #5
1969k10stepside
Tell me about it...Were your springs arched that much?
I called them,a new lift (Hopefully the right one!!) is on the way.Hopefully it's here by the weekend so I can get them on.
Old 11-08-2007, 07:37 PM   #6
62 short step
62 short step's Avatar
Wow, thats crazy!! Hope you get them, was looking forward for some pics.
62 short step is offline   Reply With Quote
Old 11-08-2007, 07:46 PM   #7
earl87gta
earl87gta's Avatar
man your having no luck with them at all.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 11-09-2007, 10:29 AM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
You have a right to be angry at them, are they doing anything to make it right? Some new rear springs for all your troubles would be cool :-)
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-11-2007, 05:15 PM   #9
1969k10stepside
The new springs showed up today..I'm gonna put them on tomorrow and hope for the best..
Old 11-11-2007, 07:39 PM   #10
1969k10stepside
Well,I went out,and put the new springs in one side and left the old one in the other side..this was to see if there was a difference between the 2.I get it all back together,get out the tape measure and measure off the same point on both sides..and guess what? They are the same!! You know what that means? These still won't work.Sure,they may be new springs but the truck will sit the same as it did before...I guess I'll call them again tomorrow I guess I'll ask for 6" front springs tomorrow and see what happens then...
B@$terd$
If I wasn't putting the lift on myself,I'd send them a bill for labor costs..hmm,I might still do that
Old 11-11-2007, 07:54 PM   #11
Ace in the hole
Man that sucks, I hope I don't run into this when I get my lift.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 11-11-2007, 09:16 PM   #12
1969k10stepside
No one else would have this issue..It's just my luck.What's that old sayin'? If I didn't have bad luck I wouldn't have any luck at all!
Old 11-11-2007, 10:08 PM   #13
1Ton
1Ton's Avatar
Sorry to hear of your bad luck. Although when useing rough country it seems to be the norm. I lifted a friends 2000 Jeep Wrangler and it took 3 weeks to get the lift in and a bunch of phone calls. Then when it got there it wasn't complete had to wait for more parts. Thier answer was to send us some hats and stickers. Like we wanted to advertise for them or something. Hope all goes well.
Support your local search and rescue team.... GET LOST!
Originally Posted by DURRTY
if some is good
more is better
too much ought to be enough........
1Ton is offline   Reply With Quote
Old 11-11-2007, 10:16 PM   #14
1969k10stepside
Well,this will be my last purchase from them..This just hasnt taken me a few weeks though..I first put the lift on in January.
It started out with a great stance..till the motor went in..
The motor still wasnt in and the front started sagging..
The front kept going down..the motor was in it then,but the truck had never moved under it's own power...I put 150 pounds of concrete in the back just to get it to sit like it is!
As you can tell compared to the K/5 with a 2" lift,it was sitting higher,but also notice the back was higher than the front...
Old 11-15-2007, 06:46 PM   #15
1969k10stepside
Well,they sent out add-a-leafs they claim will still add 2" to the springs..they better.They also sent out a few t-shirts and hats...like I'll wear them after my experience with them
Hopefully the add-a-leafs are here tomorrow.
Old 11-15-2007, 06:52 PM   #16
62 short step
I was thinking about getting a lift from them, but I dont know now!!! Good luck man!!
Old 11-17-2007, 09:09 AM   #17
1969k10stepside
Well,the add-a-leafs showed up yesterday.I got the spring packs apart,and got the add-a-leafs in..They did put some more arch on them,hopefully they allow the truck to sit level..I guess I'll find out later when I put the springs back on..
Old 11-22-2007, 12:20 PM   #18
bigrey6306
bigrey6306's Avatar
Man, What a pain...
Will never buy from those guys!
Thanks for the heads up...
bigrey6306 is offline   Reply With Quote
Old 11-22-2007, 12:37 PM   #19
Zoomad75
K5Camper
Zoomad75's Avatar
Your story sucks to have gone through the BS. I ordered my RC kit through JCWhitney and had everything I needed to my door in less than a week. Everything was correct.
So to say that either way is the norm might not be completely accurate. I'm not defending them, but that was my experience. At least they have worked with you in getting the corrective parts out to fix the problem. Other companies would have told you to pound sand.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 11-30-2007, 12:14 AM   #20
69TowRig
I think I am going with SkyJacker when I do mine.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
