Old 11-08-2007, 01:51 PM   #1
76bonanza
76bonanza's Avatar
por-15
about how much will I need to do the floor pan in my 68?
And do any of the board vendors carry it?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 11-08-2007, 02:03 PM   #2
cdowns
cdowns's Avatar
Re: por-15
you'll have alot leftover if you buy a quart
Old 11-08-2007, 02:06 PM   #3
76bonanza
76bonanza's Avatar
Re: por-15
What about a pint? I was also thinking about getting that six pack how long will it keep unopened?
1968 c10
lowered 3" 4"
Old 11-08-2007, 02:10 PM   #4
clemson71guy
clemson71guy's Avatar
Re: por-15
you will have alot left over if your just doing your floor. it dries up fast so once you open it you should paint as much as you can with out wasing it.
i ordered 2 quarts for my frame and 1 quart covered it easly and we put 2 coats on it. the other quart my grandpaw used to put on his boat trailer.
it works good but dries fast if its left open
clemson71guy is offline   Reply With Quote
Old 11-08-2007, 02:46 PM   #5
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: por-15
I'm sure how long it will keep, but the 6 pack is the way IMO. It doesn't force you to use it all up at one time.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 11-08-2007, 02:47 PM   #6
67_C-30
67_C-30's Avatar
Re: por-15
My trucks
Old 11-08-2007, 02:49 PM   #7
bobthecop
bobthecop's Avatar
Re: por-15
Where can it be purchased??
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 11-08-2007, 03:29 PM   #8
cdowns
cdowns's Avatar
Re: por-15
around here napa and carquest both have it as well as the autopaint supply stores also big swapmeets have at least one vendor theres also www.por15.com
Old 11-08-2007, 04:07 PM   #9
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Re: por-15
couldnt agree more with ya C-30 i did my frame with the 6 pack and have 1 can of each left
bad6772 is offline   Reply With Quote
Old 11-08-2007, 07:18 PM   #10
2bits
2bits's Avatar
Re: por-15
Definitely swear by the stuff, and get the little cans fer sure. You can save what's left in a little can by using a plastic baggie in between the can and the lid, that way the stuff never makes contact with itself. Make sure you have the baggie just laying flat so there are two layers in between, that gives it a plece to separate from. Wouldn't chance it with a quart, that suff is expensive!
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 11-08-2007, 07:55 PM   #11
jfalesi
Junior Member
Re: por-15
It's some weird, wild stuff. I recommend using a plastic paint container, because it doesn't stick to plastic. Any leftover paint will peel off after it dries. I used a couple of small measuring cups and dipped them into the can to avoid the mess from pouring (don't pour the POR - hah!). You still need to seal up the can right away with a plastic barrier (I used plastic wrap). You can even set painted parts on a plastic tarp and pick them right back up when they're dry. Don't try this on concrete - I know a guy who pulled up a chunk of his garage floor while trying to un-stick a used paint brush from it. I used disposable paint brushes and did all my painting over plastic. I've probably opened and closed the can 10-15 times and it still seems OK, although it doesn't spread as evenly as it once did. Didn't help that I was storing it in a humid garage in the summer (moisture makes it dry faster)... I also recommend using their metal-prep and/or scuffing any smooth surfaces. It's actually peeling off my radiator support because I didn't.
It's almost a mis-nomer to call it "paint." I think it's alien technology from Area 51.
jfalesi is offline   Reply With Quote
Old 11-08-2007, 09:59 PM   #12
jcfoote60
Active Member
jcfoote60's Avatar
Re: por-15
I used the 6 pack and had 3 cans left over after doing the complete floor area. I did two coats and it turned out great! hard as nails and like other's have said the 6 pack gives you great flexibility and left overs for other projects.
jcfoote60 is offline   Reply With Quote
