Old 11-08-2007, 03:27 PM   #1
dznucks
dznucks's Avatar
Correct name for a "3 on the tree"
What is the correct name for the three speed trannies that came in the 67-72 trucks. My truck is a 69 the originally had a straight 6.
does anyone know the size of the final drive gear?
dznucks is offline   Reply With Quote
Old 11-08-2007, 03:58 PM   #2
grancuda
grancuda's Avatar
Re: Correct name for a "3 on the tree"
Three speed on the column is the correct name for it I believe.
I am curious of the rear gear ratio also. I have been told 3.73:1 and I have been told 4.11:1 but I don't have a tach in the truck so I can't figure it.
My truck is a '72 2wd I6 w/column shift 3 speed Long fleet w/ no options other than leaves out back and the gauge package. Any ideas on the factory gear ratio?
grancuda is offline   Reply With Quote
Old 11-08-2007, 04:20 PM   #3
67shortie
Green club
67shortie's Avatar
My truck was born a 71 with the standard L6 and 3 on the column too, the stock rear end came with 3.73's in this truck. Someone will chime in I am sure with more accurate info.
Also, call it what you want but I always refered to the 3 speed on the column as '3 on the tree' too. It probably is suppose to be standard on the column or something like that.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 11-08-2007, 04:26 PM   #4
1969k10stepside
I believe the stock 3spd manuals were Saginaw three speeds,but could be wrong...
1969k10stepside is offline   Reply With Quote
Old 11-08-2007, 04:45 PM   #5
northerngmc
northerngmc's Avatar
What do you mean by final drive?
If you are wondering about 3rd (high) gear on the 3 speed. It is a 1:1 ratio.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 11-08-2007, 05:11 PM   #6
68350
68350's Avatar
3.73 i believe were STANDARD on all manual transmission pickups, blazer, burbs. auto's should have been 3.08 or 3.54 depending on 1/2 3/4 1 ton. hope this helps
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 11-08-2007, 06:47 PM   #7
67_C-30
I have a radical idea!
67_C-30's Avatar
Were 3.73's standard on V8 truck also?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 11-08-2007, 06:49 PM   #8
1969k10stepside
If they had manuals..all my 2wds with 350/TH350s had 3.07s or 3.08s unless they had been ordered otherwise.All my 4wds with 4spds had 3.73s on 1/2 tons...
Old 11-08-2007, 06:53 PM   #9
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
I guess 3 on the tree works. The owners manual says something like conventional H-pattern column shift.
Rear drive ratio seemed to vary with engine and transmission. This is what GM offered in 1970 1/2 tons:
http://www.wkinsler.com/truck/index.htm#Power, other years may vary.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 11-09-2007, 06:42 AM   #10
dznucks
dznucks's Avatar
Maybe i should have been alittle clearer. I meant to ask for the manufacturers name and part numbers associated with it.
i thought they were saginaws but i was not sure, i have never heard them called anything but 3 on the tree.
thanks notherngmc that is what i was asking for.
long stroy short i am trying to have a carb tuned to the truck and need to know, or at least act like i know, what i am talking about.
thanks all.
Old 11-09-2007, 08:49 AM   #11
When you say 3spd that means 3 on the tree to me.I guess column shift 3spd or column shift manual.It`s becoming obvious why we the people dubbed the "3 on the tree" term.Seems to work best.
