Old 11-08-2007, 04:49 PM   #1
bdmcgee
bdmcgee's Avatar
Exclamation GMC Wiring Harness
I just got off the phone with Early Classsic Enterprise. Nice guy. Seems to be a solid company. Anway, he told me the wiring harness is DIFFERENT in the Chevy and GMC? That's what he was told by the company who makes the harnesses. So, they DON'T have the dash harness for the GMC. Says it's not made. Has anyone heard of this? Will a Chevy harness fit into a GMC? I can't hardly believe it wouldn't. He said it was because of the duel headlights on the GMC. . .
As always. . any help is GREATLY appriciated guys
bdmcgee is offline   Reply With Quote
Old 11-08-2007, 04:57 PM   #2
57sailplane
57sailplane's Avatar
Re: GMC Wiring Harness
if its just the dual headlights thats nothing. the center 2 are just high beams so all you have to do is clip the plug off the Chevy harness wire the outside lights to the low beam and the center lights to the high beam and wallah! oh and ground both.. basicly if you have the plugs and wire to the gmc all you have to do is clip the wire were both go togather in the harness usally a few inches away from the low beam and splice to your new harness then wrap with eletrical tape of course i would solder the conections.
57sailplane is offline   Reply With Quote
Old 11-08-2007, 05:34 PM   #3
Ackattack
Ackattack's Avatar
I used a regular painless wiring kit for my GMC. I think I just had to tap into a wire or two for the dual headlights.
I don't see how the dash harness would be any different.
Ackattack is offline   Reply With Quote
Old 11-08-2007, 05:34 PM   #4
rogergodding
rogergodding's Avatar
I rewired mine with an EZwiring harness. I ripped out all of the old wires from the fuse block outward. EZ has to be the best one out there. Having all the wires labeled is a big plus......
rogergodding is offline   Reply With Quote
Old 11-08-2007, 05:48 PM   #5
70' GMC
HERE.......Somewhere
70' GMC's Avatar
is there a website?
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 11-08-2007, 06:58 PM   #6
rogergodding
Originally Posted by 70' GMC View Post
is there a website?
should be, I'll check.
Old 11-08-2007, 07:00 PM   #7
rogergodding
here ya go: http://www.ezwiring.com/
it cannot be made any easier..... I've used two of them.
Old 11-09-2007, 12:21 AM   #8
John H.
John H.'s Avatar
I have a factory GMC wiring diagram book for trucks built after August 12, 1968. I could photocopy the motor/light harnesses and fax you a copy. You could compare them to a chevy diagram where they go into the dash block. If colors and routing are the same, this would answer your question. Why would the dash harness be different? The cluster and interior electrical is the same on the inside.
I will soon find out as I have replaced my dash harness with a reproduction dash harness. I unwrapped my GMC and it was the same. I actually bought a harness without the gauges (cheap on Ebay) and converted it to the gauge style. There are 1 or 2 wires you need to take off the ign to the cluster that provide the lights to light up when you turn your truck on. I think I relocated a couple pins in the cluster plug too.
Good luck.
John H. is offline   Reply With Quote
Old 11-09-2007, 01:25 AM   #9
13lazer
13lazers' blazers
13lazer's Avatar
the best way to rewire these trucks is to get a few donor harnesses from ebay or the junkyard. lay the harni out on a table and repair the best one with pieces from the other ones. look for burned wires and corrosion at the plugs. i once got a boxfull of good factory wires and connectors out of a junked 1977 chevette. use solder and heat shrink, chevy trucks are very easy to rewire.
1970 2wd blazer
1972 1ton blazer 4x4 in progress
1966 mustang coupe (modified)
1985 c20 suburban tow rig
1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat
almost all exempt from california smog laws intentionally.
13lazer is offline   Reply With Quote
Old 11-09-2007, 01:58 AM   #10
mshirey
Try these guys they should have what you need. http://www.wiringharness.com/
I used their products and they are good quality and good fit.
Mike
67' GMC Fleetside
mshirey is offline   Reply With Quote
Old 11-09-2007, 12:55 PM   #11
Musclerodz
Dash harness is the same. Front light harness is different. The other issue is how the truck is optioned. There is the possibilty of several different part numbers depending on how your truck is equipped. AAW makes all the factory harnesses for the GMC and we are a dealer for them.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
