Old 11-08-2007, 06:53 PM   #1
jkade
jkade's Avatar
OK, how many with blazers laying frame??? Or Close
Seems that is is going to be hard to get the rear low using the trailing arms and not much room for a 4 link. Thinking abougt some custom trailing arms like the air ride tech arms would help with clearence. Anyone have pics of finished product? I already have the 8" notch for the rear and the bags mounts that mount to the rearend.
jkade is offline   Reply With Quote
Old 11-08-2007, 11:26 PM   #2
impala_631
:( BYEBYE :(
impala_631's Avatar
Re: OK, how many with blazers laying frame??? Or Close
if space is a issue you could run a 2link with a pan hard bar, that would keep the 4link bars from coming up into the cab, you would still have a cnotch that can be covered over easily
impala_631 is offline   Reply With Quote
Old 11-09-2007, 04:13 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
You already know where I stand. I think Bagged74 is gonna be the closest to what you're looking for- his trailing arms are a pretty good way to avoid frame interference problems. Do something like that and stack as much block in there as you can...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-09-2007, 03:05 PM   #4
jkade
jkade's Avatar
I talked to suicide doors and he said he could build me a 20 parallel 4 link that would be 20"s long. He said it would still work good at that lenght. I will have to do some measuring and see if that will work.
Old 11-09-2007, 09:36 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
I like the triangulated superlift from suicidedoors. If I were to link mine, that is the way I would go...
-Chris
Old 11-15-2007, 08:10 PM   #6
edflores
i lay frame. i have a 2 link with a panard. but mines an 81. you could do the parralel setup from sd, but where are you gonna put your bags?
edflores is offline   Reply With Quote
Old 11-15-2007, 09:01 PM   #7
PBFAB.COM
PBFAB.COM's Avatar
Just picked up a 2wd Blazer to prototype a rear kit on... hoping to have it available around the first of the year... the four-link will be designed to allow the frame to lay with the appropriate sized notch (the "appropriate" sized notch will be part of the complete kit). It'll be 100% bolt-on.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 11-15-2007, 09:45 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by porterbuilt View Post
Just picked up a 2wd Blazer to prototype a rear kit on... ..
What year Blazer?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-15-2007, 09:46 PM   #9
jkade
jkade's Avatar
Anything on the c4 dropmember??
Thanks, Kade
Old 11-15-2007, 09:55 PM   #10
Rokcrln
Rokcrln's Avatar
Originally Posted by N2TRUX View Post
What year Blazer?
It is a 70 to 72 would be my guess, What else would Nate get to play with
Hey Nate you should check into one of those DropMenbers for your new blazer, I hear they work OK
Also I have a 70 that will be laying frame in a whole new way! No details sorry.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-15-2007, 11:17 PM   #11
PBFAB.COM
PBFAB.COM's Avatar
Kevin
LFD Inc.
It will be a Dropmember poster child. Who knows when I will have time to finish it. Hopefully it won't get stuck out back with all my other trucks...
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-15-2007, 11:25 PM   #12
PBFAB.COM
PBFAB.COM's Avatar
What year Blazer?
71... it was an abondoned project. I purchased the tub, doors, and frame from the customer.
We already had replaced the front floor sections, inner and outer rocker panels (both sides), rocker boxes, lower A pillars, lower B pillars, hadn't quite finished attaching the modified SWB bedside skins, and hung some new doors. And we smoothed out the firewall.
Here's a before pic...
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-16-2007, 12:22 AM   #13
gringoloco
A guy with a truck
gringoloco's Avatar
Did he spend all his money on the rendering?
-Chris
Old 11-21-2007, 05:40 PM   #14
grnddwn
belly dragger
grnddwn's Avatar
Mines close with the trailing arms but I wanted to keep the back seat. I'm thinking dropmember in the front next year. So I can run a little bigger wheel and cut down on bump steer.
SAVE THE PLANET DRIVE AN OLD TRUCK
grnddwn is offline   Reply With Quote
Old 11-21-2007, 06:16 PM   #15
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nate is that blazer this one?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-21-2007, 06:22 PM   #16
PBFAB.COM
PBFAB.COM's Avatar
That's the one... plans have changed a little though for the end result.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-21-2007, 06:52 PM   #17
jkade
jkade's Avatar
:happy:
Old 11-22-2007, 10:15 AM   #18
Rokcrln
Rokcrln's Avatar
Nice looking ride you have their. I don't know if it is the color of the Blazer or the angle of the shot but yours is the first one I have liked with the seats w/intergrated belts. Are they sitting flat on the floor or on their stock mounts?
Kevin
LFD Inc.
Old 11-22-2007, 12:48 PM   #19
grnddwn
belly dragger
grnddwn's Avatar
Kevin
LFD Inc.
They are on the stock mounts. I had some in the back at one time but they were too tall and looked kinda silly.
