Ford Front Dana 60 Swap
Has anyone on this list swapped in a Ford Dana 6O? I know the pumpkin is on the other side but besides that it almost looks like a drop in? The WMS is within 1/4" and the spring pad span is within 1/2". I would think that 1/2" is no problem. Anyone have experience or seen any writeups on this?
Thanks, Whit |
Re: Ford Front Dana 60 Swap
vtblazer has a Ford HP60 in his Blazer.I believe member Grendel put it in though.You might pm him for specifics.You'll need a t-case with the front d-shaft on the drivers side..A FORD version NP205 maybe with an adapter,or a newer Chevy t-case.You'd get a better response in the 4wd section.
Thanks, I didn't know there was a 4WD section.
