Old 10-07-2002, 07:55 PM   #1
ira ashley
how to fix AC arm
How do you fix the AC-defrost arm? I have ordered a new one, will not be here for about 5 days.....all the help is greatly appreciated
ira ashley is offline   Reply With Quote
Old 10-07-2002, 08:28 PM   #2
Vince M
Vince M's Avatar
Mine has a plate spliced on top of the break and is riveted on with two or more rivets on each side of the break.. Might hold for a while. I've got new ones also..just have't gotten around to putting them in.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 10-08-2002, 10:45 AM   #3
Lippyp
English Chevy Owner
Lippyp's Avatar
One of the first things I did when I got my truck was rebuild all of the heater controls (non-AC, but I guess the principle's the same) Got a rebuild kit from Chevy Duty and replaced all the arms and cables. They're just held together with push on clips, took about an hour from start to finish and was real easy to do. Instructions were pretty good too. The new arms were steel rather than that cheap cast pot metal so should last forever. Gotta have heat and defrost where I live!
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 10-08-2002, 11:56 AM   #4
ira ashley
Thanks to everyone on the info
However on the AC control to remove the broken arm you must grind 2-rivits off of a small plate on the back.
The question I have is
How do you put the plate back on; the rivit is made into the complete AC control unit.....I only ground off the top of the rivits or you may what to call them studs
help help help thanks again Ira
