Old 10-07-2002, 08:43 PM   #1
muscletruck
gas pedal switcher-ru?!?
hey all, i was just doing a little interior fine tuning and i noticed that 71 and 72s have a different gas pedal than 67-69...i like the 71-72 pedal alot better.... is there any way i can put that style of pedal on my truck...thanks
i think i found me truck!
78 Crew Cab Dually
454/TH400, Dual Flows, Edelbrock Intake, Cam, Lifters, Billet Grill, K&N Airfilter, Grant Steering Wheel, A/C, soon to be power windows and locks, lots of plans for this...
....gas prices go down please
muscletruck is offline   Reply With Quote
Old 10-07-2002, 09:14 PM   #2
junkyardjohn
junkyardjohn's Avatar
Thumbs up
YEP I THINK YOU JUST HAVE TO DRILL A COUPLE OF MOUNTING HOLES.
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 10-07-2002, 09:49 PM   #3
muscletruck
sweet....thanks
78 Crew Cab Dually
Old 10-09-2002, 08:35 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
They went to a cable instead of the rod. Personally, I like the rod type. Cables can fray and stick. The rod lives forever! And if your gas pedal ever sticks like a broken accelerator spring or ???, you can pull up on the pedal if it has the rod linkage. Try that on the cable type. :p
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 10-09-2002, 09:12 AM   #5
JimKshortstep4x4
Smile
I like the looks of the 71-72 gas pedals so this is what I did upon
realizing that making a square hole for the cable was needed plus moving the holes. Also, the 71-72 cab is made slightly different to accommodate the pedal, (there is a wider flat formed at the location).
I cut the 69 pedal and welded a cut off 71 pedal to the 69
at the right location. Now I have the 71 look and the 69 mechanical rod. This seemed to be the easy to go!
The pivots in the floor always seem to rust out and cause problems and what I did works well.
Jim
Old 10-09-2002, 11:10 AM   #6
junkyardjohn
Talking
RUST???? OH THATS THAT BROWN STUFF. THAT METAL OXIDATION STUFF THAT SOME OF THE GUYS BACK EAST ARE ALWAYS FIGHTING OFF....... WE DON'T HAVE THAT PROBLEM OUT HERE IN THE DESERT OR WEST COAST.
junkyardjohn
DON'T RENT U-HAUL
Old 10-09-2002, 12:50 PM   #7
JimKshortstep4x4
Smile
John,
Have you forgotten already? I can always send you a rusty piece of a truck if you miss that part of living in Michigan.
Jim
