Heater Question
Here is my problem, I replaced my old heater motor with a brand new one. It worked fine for a couple weeks then quit for no reason.I ran a wire straight from the battery and touched it to the connection on the motor and it spun right up so I know the motor and the ground is good.I also checked the fuse and it was ok. I have it on a cheap 3 way switch for the moment but I'm thinkin the resistor is bad. Could that be it?
2002 S10 ZR2 for the dirt. 1968 C10 shorty for the street. She said the truck would be the end of us. I still have the truck! Last edited by DangerBoy; 11-09-2007 at 05:40 PM. |
Addicted to Chevy
Re: Heater Question
i would like some info on this as well. I have mine hooked up on a switch under my steering column right now too. mine is noisy and makes a loud rumbling sound. new motor or new squirrel cage in order?
Having issues
Re: Heater Question
Chev64, I would think that a new motor is in order.
Dangerboy, I would check your wiring between your heater control and fuse box, and from the fan switch to the fan. If you have access to a spare known good switch, try swapping it out.
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." |
Re: Heater Question
Thanks, I'll give it a try.
2002 S10 ZR2 for the dirt. 1968 C10 shorty for the street. She said the truck would be the end of us. I still have the truck! |
