Old 11-09-2007, 07:18 PM   #1
Duro5341
Duro5341's Avatar
Mag Hytec GM 10 bolt cover
Hey guys
Not sure if you remember my issues with this cover, and the install....etc.
Here is the Thread
http://67-72chevytrucks.com/vboard/s...num+diff+cover
Anyways I wrote them an e-mail regarding my issues, and concerns.
I have to give them some props, it only took them approx 3hrs to get back to me......so they are quick when you have something bad to say
Here is my e-mail, word for word.....unaltered
Dear Mag-Hytec
I purchased the GM10-8.5 rear diff cover on October 2nd,2007 from a online supplier, and upon installation of the product 2 issues arose in which I was not pleased with, one was the machining of the flange, and the fitment on a regular 10 bolt rear end, and the second is the false advertising on your company website regarding the 4 qt capacity
I decided to purchase your cover even though it was $100 more expensive than any other cover with the same features, assuming that with that extra money spent the machining, and fitment would be 100% perfect, and it would be a bolt on cover, with no modifications necessary. Upon installation I noticed that 1 of the 10 machined bolt holes didn't line up, and was actually out approx. 1/8th of an inch. This required me to elongate this hole, and cause me extra grief of having to use trial and error to get it to fit properly. I would expect this from a cheap cover, but not a $250 cover. This is unacceptable, and should be remedied as soon as possible, to avoid any further customer complaints.
I also liked the fact that this cover was supposed to hold 4qts of fluid, and keep the rear-end cooler, and last longer. Upon filling the rear differential to between the two marked lines on the dipstick, as per the instructions, even after the 50 mile run in period. I found that the cover only held approx 3qts of fluid. This is a far cry from the 4qts as advertised, and is completely miss leading.
In conclusion I would like to know how you plan on addressing these concerns, and maintaining me as customer, as I was looking to purchase the TH400 transmission pan when it became available aswell
Thank you
Cameron
And here is there response
Cameron,
After reading your E-mail, I went out to the warehouse and reaffirmed that the #GM 10-8.5 s/n 1945 still fit perfectly on our housing. After almost 2000 units sold we would have had more feed back about your issues with installation. And if you fill the differential to the top line that will equal 4 qts. So I am not sure what happened with your application. Have a nice day.
Dave @Mag-Hytec
Basically saying.....F*&K you,
Now I am an apprentise, I have done approx 30-40 diff services, on different makes, and models.....so I am no novice.
And my 10 bolt is like every other, no alterations to the original cover either. And how do they get 1 qt of fluid more, and not over fill it? Unless there pinion angle is straight down, and there filling the whole pot......no one could be that stupid though, could they
So who is right here?, or am I just asking two much from a $250 cover?
Duro
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
Old 11-09-2007, 08:14 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Mag Hytec GM 10 bolt cover
well id fill it to the top of the full line and see how much it holds then, but that doesnt help with the bolt being out of line... id take picturesd and send them a certified letter showing your differential and the pics and then tell them you want a refund.. id never buy one of their products again
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-09-2007, 08:23 PM   #3
Duro5341
Duro5341's Avatar
Thats just it....you fill it to the factory fill hole, and it's at the full mark on the dipstick, which it's supposed to be........but it still only hold 3.0L with 2 bottles of the LSD additive. So thats only 3.17qts of fluid. Not 4 qts as advertised
Duro
Old 11-09-2007, 09:28 PM   #4
68K20 x Drill
ummm Don't you Canuckistani troublemakers use a bigger gallon?
Not that i have anything against a bigger Pint!
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 11-09-2007, 09:36 PM   #5
Duro5341
Duro5341's Avatar
No I converted it....3.0L is equal to 3.17qts (US). Still not 4qts (US)
Duro
Old 11-10-2007, 11:03 PM   #6
Duro5341
Duro5341's Avatar
Bump^^^^
Am I being unreasonable with this company?, I am obviously being blown off...
Duro
