Old 11-09-2007, 10:13 PM   #1
buckaneer
Testing the engine. 62 C10
i have a 350 in my 62 project. The guy I bought it from said it had not been cranked in 2 or 3 years. What do I need to do to test it? I have a compression tester. One friend suggested ATF to lubricate the cylinders. This is my first restoration project. Any advice would be most appreciated.
Buck
buckaneer is offline   Reply With Quote
Old 11-09-2007, 11:58 PM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Testing the engine. 62 C10
I would use regular engine oil...as that is what lubricates the cylinder walls. Pull out ALL the plugs, and squirt plenty of oil in the cylinders.
Disable the ignition, and prop open the throttle. I would disconnect the fuel supply as well.
While your cranking the engine...you can check for oil pressure at this time as well....being your light is working, or you have a guage. Make sure, of course the engine has oil in the pan.
Once you have compression reading, you can go from there...Run it or not.
If you think there might be a possibility that the timing might be off, you can always 'static time' it before the initial fire.
Let us know what you find !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 11-10-2007, 08:09 AM   #3
hewlett2002000
hewlett2002000's Avatar
when i bought mine the PO told me the same. all i did was change the oil, plugs, wires, empty the gas tank and spray some carb cleaner and check the timing. it fired right up. but uhhhhh, then died after 2 seconds. the pickup in the tank was clogged up so i just changed the whole tank with the one from my 62 because it was only about 4 years old. started right up and ran like a top.
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
