Old 11-10-2007, 08:11 PM   #1
daveo68
daveo68's Avatar
Another tailgate problem
Got my tailgate installed and can't get it to latch. I had the bed and inside of tailgate Linexed about two years ago. I had these done separate because I had the tailgate off. The gate worked fine before. Could the Linex material be the cause of it not latching? If anyone has had this problem please let me know if you solved it. Thanks,
Dave
68 C-10 Custom LWB
307 V8
Lexington,NC
davideowens@lexcominc.net
God Bless America
daveo68 is offline   Reply With Quote
Old 11-10-2007, 09:28 PM   #2
daveo68
daveo68's Avatar
Re: Another tailgate problem
ttt
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
Old 11-10-2007, 09:41 PM   #3
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
There might be some of the Linex material getting in the way... Loosen the bolts on the tailgate catches mounted to the inside of the bed, bring them out towards the back of the truck and tighten them back up. You should be able to take care of this with an adjustment or two.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 11-11-2007, 01:22 AM   #4
daveo68
daveo68's Avatar
I've tried moving them every way and still can't make it work. I'll try again tomorrow.
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
Old 11-11-2007, 09:14 AM   #5
cdowns
cdowns's Avatar
cover thje latch hole area in the side of the bed with masking tape then take a grease pencit to the latch prongs of the tailgate to see where the alicnment problem is//i'd bet its the linex if its anywhere near the thickness as mine and its on the mating surface of the tailgate to bed it'd be close to 1/2 build up from stock
Old 11-11-2007, 09:48 AM   #6
daveo68
daveo68's Avatar
Did you get yours to fit and work right? If so what did you have to do?
Dave
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
Old 11-11-2007, 10:32 AM   #7
cdowns
cdowns's Avatar
Dave
i had my truck sprayed with tailgate on so i didn't have an issue
Old 11-11-2007, 05:39 PM   #8
see ten
WTB this ad
see ten's Avatar
If the liner seems to be hitting the gate you're probably going to have to trim it. I had to trim mine and used a dremel with a small grinding wheel. Try sending Chevydude a PM. He installs liners for a living and might be able to help you out.
see ten is offline   Reply With Quote
Old 11-11-2007, 08:29 PM   #9
Premium72
Premium72's Avatar
just switch out the bed for a stepper... tail gate will work, look better and i hear they are faster..but thats just what i heared...ha..
Premium72 is offline   Reply With Quote
Old 11-11-2007, 08:48 PM   #10
daveo68
daveo68's Avatar
A little trimimmg and some latch adjustments everything works good again.
Thanks,
Dave
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
