Old 11-10-2007, 08:11 PM   #1
1984Silverado4x4
Putting in a 454
Would I be able to drop a 454 from a 1978 Chevy 1ton into my 84 half ton without having to get a different transmission or doing any changes to the trans?
I have the 4spd manual with the granny gear and the 1978 is a auto trans
Its no disgrace being poor. Its just inconvenient.
1984Silverado4x4 is offline   Reply With Quote
Old 11-10-2007, 08:49 PM   #2
Thumpin455
My truck is an alcoholic
Thumpin455's Avatar
Re: Putting in a 454
You would need a 454 flywheel and an 11" clutch, unless you already have those. The bellhousing pattern is the same, so as long as the flywheel fits inside it you should be ok there. I used the 85 454 mounts in my 76, and a 700R4 from Diesel, and it fell in like it was meant to.
Too much stuff, too many projects to list everything.
my 454 urged 76 swb beater
Thumpin455 is offline   Reply With Quote
Old 11-11-2007, 09:42 AM   #3
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
i think the motor mounts for the big block are the same...when i bought the new ones for y 1 ton, they were the same as the ones from my 84, but man my 454 did nto want to drop over them, took forever to get it to drop in over the new mounts..
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 11-11-2007, 11:42 AM   #4
Thumpin455
Thumpin455's Avatar
I had to use the 454 stuff, but I had one of my Pontiac 400s in it before. So everything is different for mine. As long as you have th donor there it should be too tough. Are you planning to run the power steering? The 84 should have metric fittings where the 78 will probably have SAE. The return line isnt a problem, they swap easily, but the pressure line is a bit tougher. You can unscrew the adapter from the back of the pump, and install it in the other pump. BBC power steering mounts differently than SBC.
