Old 11-10-2007, 08:33 PM   #1
tkeduk8r
tkeduk8r's Avatar
Any special tricks to doing drum brakes on my Dana 60???
Im doing new shoes and pads on my new (to me) 72 c20... and just wondering if there are any tricks to doing the brakes on the Dana 60... Im planning on doing not only the shoes but also a gear lube change and possibly axle seals... any suggestions???
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 11-10-2007, 09:58 PM   #2
masterbeavis
Having issues
masterbeavis's Avatar
Re: Any special tricks to doing drum brakes on my Dana 60???
Yes. Take both drums off, only do one side at a time. Keep one side intact for reference. Axle seals are on the backside of the hub. Find yourself a brass punch, prop the hub up on some 4 X 4's, whack the inner bearing side to side till the seal comes out. Thoroughly clean the bearings and hubs, repack in grease, drive on the new seal.
Take your self adjusters apart, clean, and lube up with anti seize grease(and put a small dab of the grease on metal to metal contact points @ the backing plates.)
Buy a new hardware kit, and brake cylinders.
Re-assemble the brakes. Use some 30 something grit sandpaper to roughen up the drum braking surface, if you did not have the drums turned. Put your hubs on a bit, crank up the self adjusters so that the shoes are close to the drum surface, but not so much that you have to beat the hubs on. Install the hubs, and ONE axle shaft. When you are putting your hubs on, lube the seal surface with just a little bit of grease, a thin film. Slide it on, and be carefull to not bugger up the seal by shoving it on incorrectly,and disturbing the spring on the inside of the seal. Tighten the inner nut just tight enough to have just a touch of end play, just enough to barely feel it. Put on the lock ring, and tighten the outer one to the proper torque spec (that I cant remember at the moment) Adjust the shoes so that you barely hear them rub on the drum. Tilt the axle a bit (pointing down) to the side you sealed up, and make up a hose to fill thru the open upper side of the axle. Stop filling when the oil is right at the end of the inside of the spindle(not at the thread end.) Install the last shaft.
When you get it moving again, drive in reverse and stab the Ebrake a few times. This should help adjust the rear shoes more if you did not get them close enough. Take the truck for a spin and check the hubs for excessive heat. If they are hot to the touch, something isn't right, probably the shoes are over adjusted.
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 11-10-2007, 11:13 PM   #3
hdflstf
hdflstf's Avatar
Thanks for the detailed post 'Master..". That's one more thing I'll be getting into in the next couple of weeks to make sure I'm safe and roadworthy
hdflstf is offline   Reply With Quote
