Old 11-10-2007, 08:45 PM   #1
GMC69
GMC69's Avatar
Engine stalling
Well after I finally got the truck on the road tonight, I discovered that when you come to a stop, then try to get going again, it wants to stall, and sometimes does.
Even after warming up it has that hesitation. I tried feathering the throttle to prevent it from stalling, but that doesn't always help. I found that when I come to a stop I have to keep the rpms up a bit and it is fine.
My guess would be a carb issue. But not sure where to start looking
and on a side not, I also discovered that my rad leaks and will most likely have to replace it.
It is a 305, carburated if that helps.
Mike
Email: Click here to email me
2019 Silvedrado 4x4
1970 Chevy 3/4 ton, 396BB, on air bags
GMC69 is offline   Reply With Quote
Old 11-10-2007, 09:26 PM   #2
Thumpin455
My truck is an alcoholic
Thumpin455's Avatar
Re: Engine stalling
What carb does it have?
Too much stuff, too many projects to list everything.
my 454 urged 76 swb beater
Thumpin455 is offline   Reply With Quote
Old 11-10-2007, 09:30 PM   #3
GMC69
GMC69's Avatar
Re: Engine stalling
Quadrajet. I have one on from a friend, and I think I will put the old one back on that came with the truck, since it was the water in the old tank that was causing issues back when I bought it.
I replaced the tank and it's fresh gas, plus I emptied the carb of any water back when I did the tank.
So right now I have 3 quadrajet carbs here. the original one, one from a friend ( on the truck now), and one from the wrecking yard.
Mike
2019 Silvedrado 4x4
Old 11-10-2007, 09:41 PM   #4
spudz
spudz's Avatar
Re: Engine stalling
no vac leaks?? spray carb cleaner in isolated areas with the engine running, if the idle changes.. your leaking.. ALSO WEAR EYE PROTECTION! Also is your timming on? vac advance work?
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 11-11-2007, 10:25 AM   #5
chev74
Addicted to Chevy
chev74's Avatar
Re: Engine stalling
what recent changes have you made besides the carb?- even though it sounds like a carb thing. i had put a Holley 750 on my 350 and it would want to die too, found out it was dumping WAY too much gas in, so i had to change the jets.
Anyone know if all quadrajets came with the same size jets?
chev74 is offline   Reply With Quote
Old 11-11-2007, 12:57 PM   #6
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Re: Engine stalling
Your carb is leaking gas into the engine. I would find it very hard to believe that a Q-Jet could be rich enough to dump too much gas. I'd bet good money that it's dumping too much gas because of a leaky carb, and that's what's causing both your hesitation and the stalling.
xtreme80 is offline   Reply With Quote
Old 11-11-2007, 03:44 PM   #7
mhicks
mhicks's Avatar
Re: Engine stalling
Timing......
mhicks is offline   Reply With Quote
Old 11-11-2007, 04:16 PM   #8
bowtier
Nobody rides free
bowtier's Avatar
Re: Engine stalling
New fuel filter on it?
'71 C10 LWB 400SB/350TH
'86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck
'06 HHR - wifes wheels
'01 Blazer - daily driver
"It's better to burn out than it is to rust."
-Neil Young
bowtier is offline   Reply With Quote
Old 11-11-2007, 04:54 PM   #9
chev74
Addicted to Chevy
chev74's Avatar
Re: Engine stalling
advance?
Old 11-11-2007, 05:35 PM   #10
GMC69
GMC69's Avatar
Re: Engine stalling
Filter is new. It could be a leaky carb. I find it pretty hard on gas also. mind you I am used car, but still. I don't drive that far to work ( 10 mins) and I can almost see the gauge moving as I drive.
I might try putting the original carb on it and see, or even just rebuild it first, then put it on. I have the kit to rebuild it along with a new float.
As for the stalling, it didn't stall on me once today. It did hesitate a few times, but no stalling.
Mike
2019 Silvedrado 4x4
