70 swb question
My buddy has a 70 swb GMC with leaf springs in the rear. I thought all the early trucks had coil springs? All the brackets and mounts appear factory installed. It was originally a 6 cyl, but has a 350 now.
So did GM make leaf spring trucks in 70? Thanks!!
'71 Chevy 3/4 Ton Longbed '22 Chevy Tahoe RST '67 Firebird- 8 sec street car '24 GMC CC 4x4 Duramax Dually |
Chevy Truck Addict
![]() Join Date: Aug 2006
Re: 70 swb question
Most are coil but there are quite a few leaf spring trucks. I have a '70 Chev with rear leafs.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
Re: 70 swb question
99% of gmc are leaf chevys were coils
Re: 70 swb question
as I understood it, the half ton chevy's all got springs while the 3/4 tons got leafs. Is that not true?
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
#5 | |
Lemme show you something!!
Re: 70 swb question
Now 3/4 tons I'm not sure what was standard, optional or what not, but leafs feel right for the standard configuration with coils being optional. I don't even know if there is such a thing as 3/4 ton coil springs???
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
Between Trucks...
Re: 70 swb question
I had a '72 3/4 ton C-20 with leaf springs, and now have a '69 C-20 that has coil springs and half leaf helper springs...
Beat it to fit, Paint it to match... ![]() |
Re: 70 swb question
I had a 69 swb Chevy that was leaf spring and it was purchased that way from the dealer.A lot of the chevys were coil spring but not all of them the same goes for the small back window some will say that 67 were the only 1 that had them but there r some 68 that got them allso.I could go on and on but
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
![]() Join Date: Jun 2002
Re: 70 swb question
I have an original 1971 GMC with coils also. GM would build just about anything you wanted back then...
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
Re: 70 swb question
HUMMMMM
My 69 GMC is coil, and my 72 GMC parts truck is coil as well. Both half tons. My 70 GMC 3/4 ton parts truck is leaf.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
its all about the +6 inches
Re: 70 swb question
ok... the 1/2 leafs were not an HD option, they were simply overload springs.
There was no HD option... just HD parts. 67 - 72 chevy, bit 10 and 20 series, came with coils, and leafs were optional. GMCs, in 69, coils were standard in 1/2 ton... I believe all other GMCs, 1500 and 2500's, 67 - 72 (other than the 69 C/1500) were leaf. |
Re: 70 swb question
As stated above my 72 GMC 1/2 ton has coils!
