Old 10-08-2002, 12:08 AM   #1
stllookn
Saving 1 truck at a time!
stllookn's Avatar
283 Water outlet vs. oil filler?
Ok, How is the oil filler tube attached? Is it just pressed in? I really need to get it out of the way...routing the water outlet around the filler tube is not really what I want to do. I might just put a little indent in it to make clearance...that would work!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 10-08-2002, 12:21 AM   #2
bigjimzlll
bigjimzlll's Avatar
yes its pressed in...the manifold will have a hole that will need to be sealed..one of those expandable freeze plugs work well
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 10-08-2002, 12:38 AM   #3
stllookn
stllookn's Avatar
Thanks Jim...figured as much but I had to ask. I might try to use it since I hate to cut a new hole in the valve covers...not like this is show truck as you can see from the engine compartment...still trying to make it a daily driver...LMAO!
Old 10-08-2002, 04:31 AM   #4
Lippyp
English Chevy Owner
Lippyp's Avatar
Wouldn't it be easier just to find another filler neck with a different offset? That setup can't have been the original one as it wouldn't have been designed with no clearance like that.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 10-08-2002, 06:53 AM   #5
JimKshortstep4x4
Smile
If you plug it, won't you block off your engine ventilation? The valve covers are non vented, and I assume that the engine has the rear vent cast into the block. Blocking the vents will cause pressure in the engine and oil leaks.
Just a thought.
Jim
Old 10-08-2002, 07:29 AM   #6
Woody
You have a '67 intake but the coolant thermostat housing is from something in the '80s. Try to find a housing with out the sensors and one for a '67 so it will clear the oil tube. That way you don't have to mess with pulling and plugging that oil filler tube.
Woody is offline   Reply With Quote
Old 10-08-2002, 08:08 AM   #7
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
When you have a filler tube, the water housing faces forward or to the passenger side. You could use that style water neck and a flex hose. Or if you don't like the look of a flex hose like me, go to the parts store and match one up.
Here's a pic of the one on my 409:
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 10-08-2002, 11:26 AM   #8
stllookn
stllookn's Avatar
I have the original one...you can actually see it in the top of the picture but it requires a funky corrugated hose to be routed around the filler neck. I like the more direct route using the formed hose. I may change valve covers and put the filler and vent over there anyway. There are lots of ways to "skin" this cat...just looking for the one that will please me the most. I may even change the inlet manifold to a later version witout the filler in which case I would have to fill through the valve cover anyway.
You are all correct in your assumptions and suggestions...I pulled this filler neck off my '70's 305, hoping it would clear and allow me to use the formed hose...every little change presents new challenges...what fun!
Thanks for the help guys...this is why this board rocks!
BTW...I love that 409!
Old 10-08-2002, 01:13 PM   #9
da-burb
"Ochre Ogre"
da-burb's Avatar
Since this oil filler tube was on the 67-68's, all you need to do is use the upper radiator hose for that year of truck instead of the universal accordian flex hose.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 10-08-2002, 06:04 PM   #10
Jwill41
Jwill41's Avatar
here is mine
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
