Old 11-11-2007, 10:23 AM   #1
Olden Days
Living In The Past
Olden Days's Avatar
Anyone ever relocate the fuse panel?
I am close to wiring my project and am dreading all that under dash work. I have never liked working under there and now being a fat old man makes it even worse. I thought about putting it on the opposite side of the firewall but then I think the hood hinge would be an obstacle to reach around. Another thought was on top of the inner fender. I am going to go junkyarding to see if I can find a plastic box the right size to mount my fuse panel in. I saw a furd tauraus once that had the fuse panel fold down from under the dash. I thought that was kind of a cool feature.
Anyone one got any better ideas?
Olden Days is offline   Reply With Quote
Old 11-11-2007, 10:30 AM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Anyone ever relocate the fuse panel?
Interesting.... I don't see why not
Cool idea
My silverado actually has 2, one on the side of the dash (only acessable when the door is open) and the other is under the hood on the DS fender.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-11-2007, 02:55 PM   #3
OLDIRON69
Look at the street rod harnesses, they do some creative stuff with the harness, the inner fender sounds like a good idea, your still gonna have your dash wiring to contend with though. The fuse panel being in another spot would be nice even for us skinny young-er guys.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 11-12-2007, 06:57 AM   #4
Andy4639
Old member
Andy4639's Avatar
If you are considering moving it how about inside the glove box. If you move it any at all from the stock location it's going to have to be longer so why not? That way you open the glove box flip open the panel cover and it's right there no bending or standing on your head.
Just a idea.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-12-2007, 07:23 AM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
You will still have wiring under the dash. With the fuse box in the stock location, replacement wiring harnesses will fit without having to alter them.
I'm gonna do mine when I take the seat out, so I can get all the room that is possible. Without doing that, it would be a futile effort. At my age and my girth, futile efforts are......stupid.
Member Nr. 2770
Old 11-12-2007, 08:35 AM   #6
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
I am re-wiring my truck and generally most after market harness's, even a painless, are designed to work from the drivers side. If going with the custom location, remember stay with the same gauge wire, solder all of your ends and use heat shrink for a nice clean job.
Good Luck
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 11-12-2007, 01:55 PM   #7
Olden Days
Living In The Past
Olden Days's Avatar
Thanks for the thoughts. I know my way around both ends of a solder gun and understand proper wire gauging, I aleady bought the wire kit from Hot rod wires , so its not plug and play any ways. just trying to be a little creative with it.
Old 11-12-2007, 05:47 PM   #8
mnunn454
mnunn454's Avatar
This is about as creative as I wanted to get. I moved it a little North and East, but still generally in the same location. Had thought about relocating it elsewhere, but I didn't want to have to extend all those wires. Also thought about the "swing-down" approach, but the 18 circuit panel's a little larger than stock and I estimated there wasn't quite enough room to do exactly what I wanted. Glad I replaced the factory box. It was corroded and had a few terminals burned through.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 11-15-2007, 02:28 PM   #9
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I put an EzWirekit on the passenger side of the dash (where the glovebox would be, not a stock dash) and it seems great and I have more room to diagnose and work withouth four pedals and brackets. Some wires were extended, and I have custom gauges so I can't help you there.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 03-10-2017, 08:11 PM   #10
Meangreen1
Active Member
Bumping an old thread. Anyone ever try this?
Meangreen1 is offline   Reply With Quote
Old 03-10-2017, 09:36 PM   #11
Grumpy old man
Grumpy old man's Avatar
Why bother your not saving any space nor time
Those who attempt to reinvent the wheel are usually walking !
Grumpy old man is offline   Reply With Quote
Old 03-11-2017, 01:17 AM   #12
Meangreen1
Active Member
Other than having an ugly plug poking through.
