11-11-2007, 12:21 PM | #1 |
Recreational Grease Monkey
Mounting 12 bolt rear into a '60 PU
The rearend in my '60 1/2ton PU is apparently out of a late 60's PU. While the rearend was also from a coil spring truck, apparently my '60's trailing arms have a wider track and could not mount to the later model pads on the rear. The previous owner solved this by putting a U-bolt over the axle and into the trailing arms then proceeded to weld the U-bolt to the axle housing vigorously. He also partialy cut the old pads off. I have a 12 bolt rear out of a '73 1/2 ton with a rear leafspring. I need to find or make new pads to mount the new rear to the trailing arms. Any suggestions?
Thanks, Robert |
11-11-2007, 04:08 PM | #2 |
60-66 Nut
Re: Mounting 12 bolt rear into a '60 PU
First, did you know that your '73 12 bolt is 1.5" wider than the original one in a '60? As for the diff housing to trailing arm pads, CPP has them....just have to weld them on.
11-11-2007, 07:38 PM | #3 |
yep a bit wider, I used a 72 12 bolt rear cut off the axle perches/pads, ordered new ones (for 3" axle) and welded them on.
I will post some pics later when I can get to them (on another computer)
________________________ 62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4 08' Chevrolet Silverado CrewCab 05'Toyota Tacoma Prerunner SR5 |
11-11-2007, 10:34 PM | #4 |
Thanks for the info on the pads. Its a huge help. Thanks again.
11-12-2007, 08:10 AM | #5 |
Hollister, CA.
Hey Robert...just sent you a PM
I have some info for ya !!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
11-16-2007, 12:39 AM | #6 |
