11-11-2007, 01:48 PM | #1 |
67-72 Addict!
Please post pics of your B&M Truck Megashifter
I'm changing my regular Megashifter out for the taller Truck version and wanted to see some pics of some mounted. I'm undecided on if I want to trim the base or mount it with the angle of the floor. Thanks
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
11-11-2007, 06:17 PM | #2 |
Re: Please post pics of your B&M Truck Megashifter
mine. the switch is for my reverse lights. the megashifter comes with a built in switch, but that was missing off mine since mine was second hand.
11-11-2007, 06:47 PM | #3 |
SLOW BUT SURE,BUT CLOSER
I've got a Mega that was gave to me. Would anyone have the instructions? I need a copy. Thanks Weasel
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... |
11-11-2007, 07:06 PM | #4 |
You can download them from B&M's web site.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
11-11-2007, 10:19 PM | #5 |
Thanks, I'll do that!!
11-11-2007, 11:16 PM | #6 |
67-72 Addict!
Thanks Matt!. I copied your switch idea last year on my current shifter that I removed tonight. I started the swap tonight so hopefully this weekend I'll have the new one installed the way I want it.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 11-11-2007 at 11:17 PM. |
11-12-2007, 01:53 PM | #7 |
67-72 Addict!
Matt, I just noticed your shifter is the car version like I removed. I like that shorter look better but mine always hit the seat in first gear.
11-12-2007, 01:56 PM | #8 |
it is? for the last 3 years i swore it was the truck one? can you compare it?
11-12-2007, 04:07 PM | #9 |
Maybe an inch and a half from the bench in the rearmost rachet position.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
11-17-2007, 11:36 AM | #10 |
67-72 Addict!
I'm still in the process of installing it. Haven't had a lot of time. Matt- look at chevy72blu's base. Does yours have that bump out on the base?. It's a much bigger base than my regular Megashifter and it has an adjustbale height 3 piece bracket that the shifter bolts on top of to raise it up off the floor and change the angle. I can't get my reverse lights to work for some reason!. I did the ole' toggle switch on my other shifter but this has new switches and they don't work.
11-17-2007, 12:30 PM | #11 |
mine is the truck version, it's quite old i believe, because the newer models have the line in the middle of them for less flex. mine has the bottom adjustable bracket under it.
11-17-2007, 01:15 PM | #12 |
67-72 Addict!
That makes sense!. I didn't realize they redesigned the look of the base.
Update- my reverse lights didn't work because my fuse was blown. I felt stupid when I realized it!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 11-17-2007 at 06:44 PM. |
