Old 11-11-2007, 03:33 PM   #1
Jimma
Jimma's Avatar
Bearings inside a NP 203
I have a NP 203 transfer case in my truck. Recently the case developed a loud noise that sounds like one of the bearings is dry or bad. I replaced the bearing for the front yoke but the noise still developes after driving it for a while. I know that there are bearings up near the Trans and judging by where the fill plug is, it seems that the fluid line is lower then where the bearing is. Does anyone know what could be causing this sound and what I could do to make it go away?
Jimma is offline   Reply With Quote
Old 11-11-2007, 04:50 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Bearings inside a NP 203
I had a similar noise in my truck with an TH350/NP203 combo. It turned out to be one of the clutch bearings inside the TH350 exploded and destroyed most of the internal parts as well as cracking the case. Ya might want to crack open the transmission pan and see if you have any fragments in there before you put it in gear again.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-11-2007, 05:48 PM   #3
jaros44sr
jaros44sr's Avatar
Holy %$^&ing crap, Batman!! What a mess. Looks expensive...
Jimma, is the fluid level at the top plug?? Is it gear lube, or ATF in the transfer case?
BTW, welcome to the boards, J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-12-2007, 03:07 AM   #4
old man jimmy
Yep, oil level is to the top plug when setting level. Just like rear end. And uses 80 90 gear lub. same as rear end.
Sorry 44, I thought that was his question. Tried to delete it, but it was still their.
old man jimmy is offline   Reply With Quote
Old 11-12-2007, 06:19 AM   #5
jaros44sr
jaros44sr's Avatar
No problem Old man jimmy, takes alittle while to get the hang of it. There's more to this computer thing then I know how to use....I wasn't sure what weight gear lube went in it anyway, so you did post up useful info.
After you submit your reply, go back into edit, I think the delete button is there... then save. J
SAFETY FIRST
AS usual, off topic
Jim
Old 11-12-2007, 07:12 AM   #6
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Sorry I'm no help here, but welcome to the board.
Where in Michigan are you from?
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 11-14-2007, 09:05 AM   #7
Jimma
Jimma's Avatar
Thanks for the pictures, I will have to look into the trans. God I hope that isn't the problem...I am a student at GMI (Kettering) in Flint, MI and I live in an apartment right now, they don't take to kindly to people working on their trucks.
Old 11-14-2007, 02:09 PM   #8
Chevyman63
Chevyman63's Avatar
Cool, I'm only about a 1/2 hour away from there. My cousin's boy goes to Kettering as well.
Good luck with the transfer case. Let me know if you need a place to work on it, I may be able to help.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 11-14-2007, 02:57 PM   #9
vtblazer
vtblazer's Avatar
Why would there be 203's in your trucks?
Previous owner changed em out from the 205's?
BTW:
ATF is fine to run in a 4spd, can't imagine is wouldn't be fine for a T-case too.
vtblazer is offline   Reply With Quote
Old 11-14-2007, 04:03 PM   #10
bouncytruck
SKINNY TIRES RULE!
Mine was a swap from a 307/3-speed/Dana20 combo.
bouncytruck 1972 K5
