Registered thread killer
Sticky power steering?
Hoping someone can help me out here. I just finished converting my 66 c-10, to power steering. I am using a 1984 gearbox, and a 1990 rebuilt pump. Problem is that the steering seems a little sticky. It turns very smooth and easy, with very little play if any. It does return somewhat after a turn, but on straight driving it is pretty sticky, as I can turn the steering wheel and it will stay pretty much where I put it. It is sorta a bother when traveling because when you try to compensate for a little drift, I sort of end up Sig sagging down the road. It was not doing that before the swap. Any help would be very much appreciated.
!966 stepside, 350 SB, ZZ-4 roller, Crane roller rockers, 0.030 flat tops, airgap intake, 750 Holley, stainless steel headers, edelbrock SDT mufflers, Mark 8 elec fan, 700R-4, column shift |
A guy with a truck
Re: Sticky power steering?
Did you set your caster for the power steering?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
I had the front end aligned after I did the conversion. I can only assume or hope they did that right.
It almost sounds like you still have air in the system
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
OK, maybe there is something wrong with the gearbox. With the truck jacked up and engine off, the steering is very hard in the netrual position, but about one turn of the wheel either direction and it gets easy. Couyld there be something not working properly in the gearbox?
its only natural that the gear box have wear in the centered position... Thats where the wheel is at most of the time.. Its prolly just a worn box.. And also... alot of alignment shops go by the phrase "Set the toe, and let it go" Very posible that you still have the caster settings for a manual steering truck.. Its diff between power and non power.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
Thanks for the replys. I just bought a rebuilt gearbox. I will let ya know if that solves it.
It was the gearbox. It doesn't allway's pay to try and save a buck
laying low
![]() Join Date: Mar 2001
So you bought a remand gear box through a local parts store? Glad to hear it took care of your problem. Sure makes a nicer rig with power.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#10 | |
laying low
Saaaay, you've got a sweet setup there. zz/ od and all already. You're gonna love driving it now for sure. Gas is always going to be high so get used to it. Drive that truck!
I know you bought a new one already, but it sounds almost like your high point on the gearbox was just a bit too tight
#13 |
I am having the exact same problem with my newly installed power steering. Before shelling out the cash for a remaned gearbox I was wondering if there were any other ideas out there as far as what I could do to troubleshoot. Such as how do I adjust the high point on my box?
Thanks Mark |
