Senoir Member
Side Trim Install
Has anybody installed new upper trim? I'm installing new trim on the newly painted truck, it has new bedsides, so I have to drill those holes yet. The problem is, the trim on the original doors and front fenders lines up OK, but when I mark the holes on the new bedsides the same as the old bedsides, the trim runs downhill from the rear of the cab to the rear of the bed at the top of the taillights. It looks really crappy when you look down the side of the truck from the front or rear. The trim holes are 8" down from the top of the bed at the cab, then 9" down from the top of the bed at the rear near the taillights. Do I have to pull a string all the way down the truck and files the holes or what am I missing. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
![]() Join Date: Oct 2005
Re: Side Trim Install
Mine was like that and most I've seen are the same.
I didn't put my uppers back on but if I were you, I would use masking tape to lay out the shape of that rear mldg. so it looks right and see if the rear mldg has a little flex in it Use the clips with dbl sided tape and just follow your tape line to the hole you drilled at the rear of the bed. I think if you lined that bed mldg up straight with the rest, the rear would be too high.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
I have a radical idea!
The molding on the pass side of my '69 is in factory location, and the one on the driver's side is put on with the adhesive clips from LMC. The pass side looks like you are describing, it goes downhill. I am going to take it off and do it like I did driver's side.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Lemme show you something!!
My '67 doesn't have upper moulding and I've never installed this stuff before. But when I look @ 67_C-30's red SWB- I think the right side (Factory) attachement is correct. It follows the profile of the bed as it gently flows southward. Having it arrow straight and not following the body lines , IMO looks kinda cheesy! But to each their own....do what you think looks good.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
I'm with Dingfodgy.....but I'm guessing that with how long that mldg is, it probably has enough flex to make it curve just enough so it doesn't look "wacked".
It actually won't flex. That's what I tried to do. I installed it with the adhesive clips because the the piece of trim was damaged. I lined it at the front and it does taper down, just not as drastically as the pass side. the pass doesn't even line up correctly at the top. The bottom lines up perfectly, but the top is almost 1/2" higher at the front. If you saw it in person you'd agree that the pass looks much worse than the driver's side. I'm considering doing what you did Sacto, and eliminating the top trim altogether when I have it painted.
Well I'm glad I didn't go back to a two color combo (almost did) cuz that would've pissed me off!
I hate when mldgs don't line up correctly. 67_C-30 - I like the top mldgs only cuz they make the truck look a little more deluxe, but they just look cleaner with just the lowers IMHO.
Senoir Member
Thanks everybody! Mine looks exactly like the passenger side of 67 c-30's truck. I never noticed this before I took the truck apart.
67 C-30, Can you add a picture of each side that will show the side trim and how it lines up with the tallights? Mine will line up with the taillight trim once everything is installed. Just wanted to compare the two sides. I'll have to find my pictures before disassembly to see how it looked. Thanks, Greg
These are the best 2 I have on file. I can get you some more tomorrow. I'll also get measurements from the top of the bed to the moldings on both sides for you.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 11-11-2007 at 09:42 PM. |
#2
Always wrenching!!
mine are all orignal never been off.... they look to slowp down too
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 |
#13 |
www.67HEAVEN.com
Very nice trucks in this thread.
Is there somewhere on this site that has information (with photo examples) of the various trim levels for each model year? Although many of you will instantly recognize a truck's year and trim level, I'm still running to catch up. ![]()
www.67HEAVEN.com 2004 Z71 Tahoe 4x4 5.3L (factory white monochrome theme) 1989 Silverado K1500 4x4 5.7L sportside (white monochrome theme) 1967 Belair 2-door-post (project) 1967 Corvette 427/435 coupe (now 502/502 red road warrior) ![]() |
#14 |
On the road
![]() ![]() Join Date: Jan 2004
Every stock one I have ever seen slopes downward. The top of the side trim will be at the same height as the top of the tailgate trim when it's on as it came from the factory. My 72 is like this.
Mike
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
#15 |
Senoir Member
Thanks everyone for the info and pics. Greg
#16 |
Junior Member
:[QUOTE=GSFMECH;2442229]Every stock one I have ever seen slopes downward. The top of the side trim will be at the same height as the top of the tailgate trim when it's on as it came from the factory. My 72 is like this.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
#17 |
I just went out and took some measurements on my molding, and I (unwittingly) ended up at within an 1/8" of being the same on the rear. The passenger's rear (factory holes) measures 8" from the top of bed to the top the molding. The driver's side rear measures 7 7/8" from the top of bed to the top the molding. It too close to even tell by eye. The front is dramatically different though. The passenger's front (factory holes) measures 6.5" from the top of bed to the top the molding. The driver's side front measures 6 7/8" from the top of bed to the top the molding. The drop on the factory molding is 1.5" from end to end and mine is 1" from end to end. Incidentally the trim on the cab to the top of the bedside measures 6 7/8" just like the I made the molding on the driver's side measure. For some reason the factory holes make the bed molding 3/8" higher than the molding on the cab and doors. You could consider it cab sagging if the lower molding didn't line up, but the lower molding and body seam lines up perfectly on both sides. You can tell in the pic below that my upper molding still follows the body line on the bed. It just no longer sticks up higher than the cab molding. Correct or not, I'm not going to let that molding on the bed not line up with the cab. I don't mind the factory drop, but I want it line up from piece to piece. It makes the truck look like it has had the molding installed incorrectly. When I repaint it, I will drop the rear of the molding down to the proper 8" on both sides instead of the 7 7/8".
#18 |
Senoir Member
Thanks for the details. On mine the cab and bed line up good, it was the drop that threw me off. Greg
#19 |
Chief Honcho In Charge
I think having the trim parralel to the lower trim provides a beefier look. The downward (even slight) angle to the rear gives a more aerodynamic appearance.
I like both...it is all in the eye of the beholder. Tim
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
