Old 11-11-2007, 06:32 PM   #1
uncle
1/2 Ton Dana Posi
It's a 3:54 6 lug leaf spring Dana posi from a 68 GMC. $200. Please respond to post.
uncle is offline   Reply With Quote
Old 11-11-2007, 11:38 PM   #2
masterbeavis
Having issues
masterbeavis's Avatar
Re: 1/2 Ton Dana Posi
Looks like a power lock, good stuff. Any idea on the shaft spline count?
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 11-12-2007, 05:15 AM   #3
uncle
Not sure. I've only had a few of these and not that familiar with them.
Old 11-12-2007, 10:54 AM   #4
oldsmobilekindofguy
if only you lived closer i don't even want to know what it would cost to ship to SD
1967 c-10 longbox project, check it out in projects
1969 c-10 parts pickup, twisted frame
Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block
oldsmobilekindofguy is offline   Reply With Quote
Old 11-12-2007, 03:41 PM   #5
uncle
Your looking at least a $100. I can check if you send your zip. I'll work with you on it if you're interested.
Old 11-13-2007, 04:27 PM   #6
uncle
Bump.
Old 11-14-2007, 08:14 PM   #7
uncle
Ttt.
Old 11-14-2007, 09:03 PM   #8
BCOWANWHEELS
look on the bottom side web casting it will have a 44 or 60 cast into it. if its a dana 60 i,am almost sure it will be 30 spline. killer deal uncle.......
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 11-14-2007, 09:18 PM   #9
Tim Christian
Tim Christian's Avatar
All 1/2 tons I have seen has Dana 44's Tim I am interested. Man you are killing me!!!!!
Tim Christian is offline   Reply With Quote
Old 11-15-2007, 12:06 AM   #10
Rod
I've never come across these 1/2 ton dana ....good pics to see.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 11-15-2007, 05:04 AM   #11
w314speed
I'll go next in line after Christian.
Thanks, Dan
w314speed is offline   Reply With Quote
Old 11-15-2007, 07:52 AM   #12
uncle
I can bring it to Moultrie.
Old 11-15-2007, 08:41 AM   #13
Nice rear!!
Old 11-15-2007, 12:59 PM   #14
Tim Christian
Bring it! Thanks Tim PS: Please don't put any oil back in it if drained.
Old 11-15-2007, 03:15 PM   #15
uncle
It's full,do you want me to drain it?
