resident wrencher
haeders
dose any one have headers on their trucks do you have full lenth or shorty block huggers what
Re: haeders
I have a set of Hookers on my '65 with a small block.. they are full length with 2.5" collectors rather than the normal 3" collector.
I am fixing to pull my engine for a re-ring and bearing job and will either install some ramhorns or Hedman hedders. I found the only way to get the Hookers to seal were by cutting the head flanges and using Fel-Pro gaskets exclusively. |
resident wrencher
Re: haeders
you didnt have to notch the frame to get them in
![]() Join Date: Sep 2006
Re: haeders
Not with a small block.. Big Block you have to do some cutting..
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
Re: haeders
I run a set of Hooker 2452 headers. Had to do some clearancing for clutch and at least one plug...what else is new. They haven't leaked even once in 5+ years, best headers I've ever had.
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
Why does it taste purple?
Re: haeders
I have a set of Dynomax Headers that are just sitting up in my attic.Im not sure if they are goin to clear the clutch bar on the frame.If they don't,what can I do to make them fit?
Re: haeders
i got shorty block huggers
ridin big yo 5in cpp lowerin springs in back lowered 3in in front with cut springs for now 5 lug swap and disk in front 5 lug and disk in the rear with 3.23 gears mild 350/400heads 7547weiand intake 600 Edelbrock chrome block hugger headers 2 1/2 pipes in to a x pipes super 40 flows and turn downs turbo 350 with shift kit |
Re: haeders
I did, but they habg below the frame, they were a set of hedmann's. I'm going to lay frame, so it's a no go for me.
Re: haeders
I use shorty block headers.
This one time at bandcamp, in my c10, I ran over the girl hiding the flute! ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=255141 |
Registered thread killer
Re: haeders
Another shorty block huggers here, no issues
!966 stepside, 350 SB, ZZ-4 roller, Crane roller rockers, 0.030 flat tops, airgap intake, 750 Holley, stainless steel headers, edelbrock SDT mufflers, Mark 8 elec fan, 700R-4, column shift |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Re: haeders
Didn't have to do any cutting on the full length bigblock headers in my K10. I don't remember the name of the headers but call http://www.summitracing.com and tell them what you have and they will head you in the right direction.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
Hollister, CA.
Re: haeders
I too am running the short block hugger...I tucked my exhaust above the bottom the frame......planning ahead for bags.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
#13 |
resident wrencher
Re: haeders
real nice cheif and thanks to every body hey cheif whats up with your water inlet thing (the words escaped me)
#14 |
resident wrencher
Re: haeders
i mean its backwards
#15 | |
Re: haeders
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 11-14-2007 at 12:21 PM. |
#16 |
Old Time Rodder
Re: haeders
Am running Sanderson block huggers and had to cut the side off the driver side motor mount. Just a small amount for clearance, didn't have to remove, just used a torch. When I replaced the engine just dressed it up a little before reinstalling. I had Hedman regulars and didn't like them dragging all the time, since I have a 4/6 lowered truck.
79 GMC SWB Lowrider Stepside [81 cab] that thinks it a Chevy (since 6/1980) Replacement cab had A/C which now works, made a real truck out of it 84 MC 305 350TH 3.08 4 wheel disc finally My daily driver again |
#17 |
Re: haeders
Sanderson Headers 3/4 length. This particular header was designed to fit lowered 67 - 72 trucks and therefore no mods are necessary. For gaskets I use Permatex Ultra Copper.
esll.
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) Last edited by EAST SIDE LOW LIFE; 11-14-2007 at 01:35 PM. |
#18 | |
Re: haeders
I couldn't really tell, are you running a manual transmission? Do they clear the clutch rod linkage? |
#19 | |
Re: haeders
![]() Quote:
I'm running an auto tranny. I purchased my Sanderson's through ECE and there tech line is very helpful as I really don't know about a manual trans. They do not specify auto only. I can tell you that these are the nicest headers that I have ever owned and they cured my scrapping problem that I had with my long tubes esll. ![]()
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) |
#20 |
SIR
Re: haeders
...ceramic coated ,full legth headers...."flo-master"
66long low fleet http://community.webshots.com/user/LVNR66 |
#21 |
resident wrencher
Re: haeders
hey east side low life whats the # for the place you got your sander sons and how much were they
#22 | |
Re: haeders
Hi there Kris, The Sanderson headers [ECE's part #11 - 6572] were $379.00 bucks. Let me say though they are quality from the get go. I have two phone #s .... 1.) Order line - 888 - 777 - 0395 2.) Tech line - 559 - 299 - 1611 I hope this helps. These #s will get you in touch with ECE who is a dealer for Sanderson and their price is better then going direct to Sanderson. esll. ![]()
#23 |
resident wrencher
Re: haeders
thanks esll
#24 |
Re: haeders
i have long tube headers on my 66 with the 3 inch connecter but i had to put heat wrap on them cause my starter keeped burning up
#25 |
Re: haeders
When I had longtubes I had starter problems as well. I went to a heat shield [metal[ and it solved my problems. I left it on my starter when I changed to my 3/4 length headers.
esll. ![]()
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) Last edited by EAST SIDE LOW LIFE; 11-14-2007 at 10:42 PM. |
