Belt Drive System
I need a advice on putting together the correct pulleys and brackets for a ZZ502 crate engine. I need the alternator bracket, power steering pump bracket and shaft pulley. Any suggestions?
Bill Durham http://home.attbi.com/~bulldurham 72 Cheyenne Restoration in progress Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed. |
Carolina Classic Trucks
I can get you the March Performance Big Block setup.
![]() ![]() Last edited by Church; 10-08-2002 at 07:14 AM. |
How much?
This is kit #23020. It drives the water pump, alt, and p.s. w/ a keyway type pulley. It runs 486.00 w/ shipping.
I was looking through one of my web sites and just happened to come across this, it might help you. Once you get on the site just scroll down, you will see a picture of a guy setting up a 502 with pulleys. I hope it helps some. http://hotrodgossip.com/
Sam
72 LWB chevy truck. Pasadena, Texas |
