help with crate engine/question
I bought a 350/290 hp longblock crate motor. There's a piece of cardboard where the intake manifold goes. Under the cardboard is a bag with 2 timing cover marks that you bolt on and 2 pins. Where do the pins go? Maybe one plugs the extra dipstick hole? They are different sizes. 5/16" and 3/8"
I called chevy and they don't know. Please help |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: help with crate engine/question
Yes indeed. Plug the appropriate plug into the unused dipstick hole.
I like to go the the stealership and buy a 88-95 truck 350 dipstick and tube for all my old trucks. They go into the passenger side of the engine and are nice and long with a tee handle. Much nicer to use than the old original driver's side unit was. Under 20 bucks total.
So 1 plugs the unused dipstick hole. Where does the other plug go?
Chinook Arch
I think 1 plug is for the passenger side dipstick hole, and the other is for the drivers side hole. Different sizes for each side. The 2 timing pointers are for different size balancers, also. Just giving you some options.
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus. Elsie's truck 2.5" dual exhaust with Hooker Aero Chambers Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350 ECE drop 3.5/5 |
![]() Join Date: Jul 2007
If they didn't send extra parts you can say you installed it correctly
![]() I agree with the above posters |
The other one goes into the section of your toolbox where you keep all the knick-nacks you say you'll use someday but never do.
#7 | |
![]() I have a whole section of my shop devoted to that. They did this since it is a block for multi applications. One thing I didn't find with my block is a short bolt to seal where the fuel pump pushrod bore is exposed. |
