Tranny Cross Member Removal?
I am going to remove the crossmember that was for the three speed tranny in my C10. What is the best way? Big hammer and chisel? Heat up the rivets and chisel? I hope that I don't have to raise the cab, but it looks like it might be necessary to be able to reach the rear rivets. I may take the grinder to the bottom ones. Replies?
Richard Dobson |
Dave's not here, man
Re: Tranny Cross Member Removal?
I'm not sure if it's different for different years, but x-member in my '68 had bolts holding it in place. I was barely able to get a wrench on the bolts that lie under the cab and I didn't put them back after I reinstalled the x-member. ( I cut the upper "wings" off with a torch to make the install easier) If your truck has rivets I'd try and grind them out if you can get at it with a grinder. I think a chisel may be slow going.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 11-11-2007 at 11:08 PM. |
Of all of the 67-72s I've ever had..the tranny crossmembers all bolted in.
Watch out for your cornhole !
![]() Join Date: Jun 2003
Fellas, he's talking about his 3 speed. Factory standard trans crossmember were all riveted in on 2wd trucks.
I usually take a sawzall and cut the center section out leaving the 4 flanges on the frame, then use the sawzall to shave the rivet heads off. Use a big hammer to knock the flanges off now and the rivet body's will pull right out. It's a pain no matterwhat though.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 11-11-2007 at 09:35 PM. |
I just did one with a sawzall and angle grinder.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() |
