11-11-2007, 08:58 PM | #1 |
Confirmed Truckaholic
1/2 And 3/4 Frame ??
Are the frames the same or are the 3/4 heavier and wider?
1968 50th STEP SIDE SHORTY, 350/350, a/c, ps, p,b Daily Driver, 1970 Cst short fleet, all black, 350/350, 1970 2wd Blazer, 2wd, 6 cyl. 3 spd, original, now a 454, 350turbo, 3.73 posi, on the road 1971 2wd fleet shorty, 454, 700r4, 3.73 posi, SOLD to 67OLDSTYLE72 "My rig's a little old but that don't mean she's slow" - SAWYER BROWN's Six Days On The Road SEMPER FI "I use to be a lean mean fighting machine, but now I'm a huffin, puffin, over stuffin love muffin" |
11-11-2007, 09:07 PM | #2 |
Re: 1/2 And 3/4 Frame ??
Basically the same.I've heard the 3/4 tons may have had some more bracing but don't know for sure.The one tons is when they used a lot heavier frame.
11-11-2007, 09:08 PM | #3 |
Step Brother
They are the same frame....George
11-11-2007, 09:12 PM | #4 |
its all about the +6 inches
some added bracing, and they don't use the C/10 specific cab mounts.
11-11-2007, 09:27 PM | #5 |
Watch out for your cornhole !
No sir, the 3/4 ton has added braces in two areas....
From the trailing arm crossmember to frame rails there is a diagonal brace on each side. In the area above the rear axle where the coils mount there is a doubler plate. I've posted pics of this before on here, I'm trying to search the pics out.
11-11-2007, 09:49 PM | #6 |
I found the pics I posted awhile back...
This subject comes up a lot and folks are kind of sketchy on the details, so I took these pictures to illustrate the different areas where the 3/4 ton frames are beefed up from the factory.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 11-11-2007 at 09:50 PM. |
11-11-2007, 09:59 PM | #7 | |
Step Brother
11-11-2007, 10:03 PM | #8 |
No sweat. We're all here to learn from each other.
11-12-2007, 05:37 AM | #9 |
for all practical pourposes... they are pretty much the same. You can swap one for the other and never know it. Just remember to use the cab mounts for the specific frame.
11-12-2007, 08:46 AM | #10 |
Thanks for all the answers.
11-12-2007, 08:48 AM | #11 |
Side note; If it's a longhorn 3/4 ton of course it's way different.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
11-12-2007, 07:29 PM | #12 |
good call WL... if it's a longhorn, it's a one ton frame, which is longer, and a taller C chanel, and has big leaf springs out back.
