11-12-2007, 01:35 AM | #1 |
trans help ??
i going to look at a saginaw 4 speed for my 68 on sunday. if i were to pull the side cover off what would i be looking for to tel if it is good or not ?
any advice ??
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
11-12-2007, 02:10 AM | #2 |
Re: trans help ??
ttt
11-12-2007, 02:32 AM | #3 |
Re: trans help ??
Look for obvious broken gears. Also on the gears their are small teeth that align with the brass syncrohnizers. If any of them are chipped that is a sign of hard use or abuse. If they are chipped enough they will not hold the transmission in gear on decelleration causing it to jump out of gear.
Russ |
11-12-2007, 09:02 AM | #4 |
Re: trans help ??
Not an expert here but I'd also check shaft end-play.And pour a little oil out and if it looks like silver or gold paint then pass on the deal.Look at the shifter forks for lots of wear,also blue gears not a real good sign.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
11-12-2007, 12:10 PM | #5 |
Re: trans help ??
thanx for the advice
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB Last edited by cstm68; 11-12-2007 at 12:10 PM. |
