84 Guage cluster with TACH!!!!
I cut the plug behind the dash so it can be wired for the tach. I've seen fewer of these than ones for 67-72. Could use some clean up but these are really rare. $140 and $10 to ship it.
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing. |
Re: 84 Guage cluster with TACH!!!!
Is the mounting tab on the left hand side intact?
Oh,you can't buy that new
![]() Join Date: Apr 2000
hey fellas, i'm not tryig to take anything away from davidh cause it's a afair price, but always look at that lower cable guide for the gear indicator if you have an automatic. notice this one is broken and there is nothing permanent you can do to fix that. You have to find another way route for your cable.
whiskey- good catch on the left tab, a lot of people on ebay purposely dont show that ,BUT that left tab doesn't mean a whole lot. the way the lower part of the cluster tucks in behind the metal dash does not allow the cluster to move around a lot. You can also make a small metal tab bent 90* and screw it to the side of the plastic if you really want to. the tabs to worry about are the top two towers. they are the ones that are a real pain to fix if they are broken and they hold the gauge bezel on. Tachs are very easy to test at home also. expensive to repair though if bad. crossy
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. Last edited by crossy; 11-12-2007 at 09:16 PM. |
give ya 75 shipped.....
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
I will keep it as a converasation piece before I sell it for $75
You can get the back white shell part from LMC I believe then all the outer broken parts are fixed
Without tearing into mine, does anyone know if the speedo can be swapped out pretty easily on those? Since mine is in KM/h. It's no major issue to have it in MPH, but still.
Also in my truck I do not have the gear indicator either, so to me it's no major issue.
Mike Email: Click here to email me -- 2019 Silvedrado 4x4 1970 Chevy 3/4 ton, 396BB, on air bags |
yeah, not hard to change them out. I've done it with gas guages before.
