Old 11-12-2007, 07:43 PM   #1
Richard Dobson
Tire Size Question
I have a fleetside 71 C10 with 8" Chevy ralleys. What is the widest tire I can put on the rear. My truck is lowered 3" in the rear. It now has 235/70/R15's on it.
Richard Dobson
Richard Dobson is offline   Reply With Quote
Old 11-12-2007, 07:48 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: Tire Size Question
Since your rim is only 8", I probably wouldn't go over a 295/50. That might even make the sidewalls bulge some. I run 275/60/15 on all four corners to fill out the wheel wells but I want wider in the rear also!. I'm looking for a set of 10" rears.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-12-2007, 08:16 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I agree with 70c10 on this. There are basically two tires worth considering. The 295/50 and 275/60.
The 295 is a bit wider, at the expense of being 26.6 inches tall.
The 275 is a bit narrower, but is a full 28 inches tall, which is basically stock height.
I prefer the taller 275 tire to keep the speedometer accurate and the rear end ratio normal. A much shorter tire like the 295/50 will cause quite noticeable increase in engine RPM due to it's smaller circumference.
I have them on the back of my lowered 72 in my signature.
Old 11-15-2007, 12:30 PM   #4
Richard Dobson
70C10 & Tx Firefighter thanks for the replies, I rechecked, mytruck's drop is 2-1/2" front and 3-1/2" rear. That's with a 6cly 3 spd which is being swapped out for a 396 w/400 turbo. So I guess the front will drop further. I like the sound of the 275/60/15, since the gear ratio will be more like stock (which is 373:1).
Do you think this setup will look and run well? Thanks again.
Richard Dobson
