![]() Join Date: Apr 2001
if you havnt changed you rear end gear oil since the 70's you may have this...
Just doing new brakes, heater core, tranny flush and filter and rear lube as I do with any new vehicle I get... so I cracked the differentil conver on the Dana, and I get this... WOW!!!! thought I only read about this kind of thing....
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
Re: if you havnt changed you rear end gear oil since the 70's you may have this...
Ewwww. Looks like it needs some pepto...
its all about the +6 inches
like I ALWAYS say when ppl ask about gears.... drain the oil. It is even more neglected than brake fluid.
Yuck!That's why I always change the fluid in the differentials when I get one if I plan to drive it any,and also why I tell people when they want to know their gear ratio to pull the cover and get the numbers from the ring gear,and replace the oil!
Always Fixing Things
Just make sure to add some more sawdust in there when you add the new gear-oil. That way, it will still purrrr..
![]() I had some chocolate milk in mine one time...I decided I would not back down into the lake anymore to unload the Jetski. None the less, a couple month later, new carrier bearings.
Just an Average Joe ![]() ‘68 GMC 307 3spd – My dad's original truck 310,000 miles |
#6 | |
Addicted to Chevy
Travis
travis_moffatt@hotmail.com ![]() 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
Just Flush It All Out With Brake Cleaner. And Then Fill It Up With Lucas Oil. And Hope For The Best
![]() It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
I wouldn't bother with lucas... most of there products are snake oil anyways. I WOULD clean it up real good, I would consider pullin the axles too... but once I knew all the water and crap was gone... I'd go with a synthetic oil.
Did it run out of there or roll like a terd?
I am swapping motors this weekend in my '67 and drained the oil in the SM465, and at least a quart of water came out the bottom. It hadn't been driven with the water (I think it was stored somewhere where the roof leaked) so it was not mixed with the oil, but some nasty chunks came out. We took the top off and blew it out pretty good with brake cleaner - hopefully it's good to go.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Synthetic Oil Is Great Stuff, But You Will Find Using Synthetic In Old Gears Will Cause The Gears To Heat Up Quicker. Thats A Fact I Learned Working On And Around Gears In The Shop Where I Work.
#13 |
to a point yes... but not overheat.
#14 |
Do the best you can to get the junk out, fill it with good gear oil, run it for 100 miles and drop it again. When you drop it the second time make sure the fluid is at operating temp so it will flow better and the contaminates will be suspended in the oil. Refill will good gear oil and keep your fingers crossed...
Good Luck!!!
1972 Cheyenne C10 Unrestored Original-3 Owner-RUST FREE Texas Truck Big Block-TH400-PS-PB-AC-AM/FM Radio |
#15 |
Let Me Explain It This Way, With All New Gears It Is A Wise Idea To Run Syn. But With Gears With Age And Miles On Them, The Strength In The Metal Has Weakened Over Time. So The Thicker The Oil The Less Heat It Builds. Lucas Works Well In Keeping The Gears Lubed And Keeping Down Heat For More Life
#16 |
Who's got steelies?
![]() Join Date: Feb 2006
Pictures like that make me cringe when I hear my dad say things like "unless its leaking, don't touch it".
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
#17 |
Active Member
![]() Join Date: Jul 2007
