11-12-2007, 10:07 PM | #1 |
What in the $%^& - undercoating?
I was looking at a truck and (as always) - I asked for pix of the key locations...
He (the current owner) sent me pix of the underside of the cab... I have never seen anything like this...anybody know what the heck this stuff is? I realize that it is some type of undercoating, but why... I asked for pix of the floor pans on the inside - haven't seen those yet - - that should be interesting. rockers are solid (replaced/rivets) - kick panels are solid (replaced/rivets)...windshield seam/upper metal area - no rust... Inner passenger rocker - (from pictures below) seem to be gone... I have NEVER seen this on the bottom of a cab - figured some of you others may have come across this...is this a red flag or should I wait to see the floor pan pix? Thanks again for your assistance everybody! |
11-12-2007, 10:11 PM | #2 |
Re: What in the $%^& - undercoating?
I would doubt how solid the rest is on the other side of the undercoating if the inner rocker is gone.
11-12-2007, 10:21 PM | #3 |
Active Member
Bondo?
11-12-2007, 11:10 PM | #4 |
Chevy Truck Addict
I was thinking fiberglass??? If there is a patch that big I expect the metal in the area is "gone".
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
11-12-2007, 11:17 PM | #5 |
11-12-2007, 11:42 PM | #6 |
Avoid!! Doesn't look good from here. That rocker looks bad and appears to continue into the floor pan.
1970 Chevy C10 "Under Construction" 2002 Chevy S10 V6 |
11-12-2007, 11:55 PM | #7 |
Questionable
it looks like freakin JB Weld, but i'm thinking bondo.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
11-13-2007, 12:49 AM | #8 |
Fast-setting roofing tar??
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
11-13-2007, 01:35 AM | #9 |
At first glance I thought that it was some sort of tar, but I would have to guess that it is probably bondo
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
11-13-2007, 02:28 AM | #10 |
Don't know what that is..........
Many years ago I had a 1970 Buick Electra 225 beater special that had holes in the floorboard that were big enough for Fred Flintstone to use. I put some old scraps of thin sheet aluminum siding under the carpet, and then crawled underneath with a can of that foam insulation they sell at your friendly local home improvement center, and filled in all the gaps from the "patch panel" I made. It looked ugly as heck, but it kept my feet from getting soaked on rainy days, and reduced draftiness quite well.
_____________________________________________ 69 C-20 292, 4 spd O/D, 4:56 rears. No a/c p/s p/b p/w......restoration project,"Operation:Stovebolt" 78 C-10 305 TH350 new (old) daily driver 02 Suburban Z71 a.k.a. the family truckster 99 Silverado 1500 Z71 |
11-13-2007, 07:25 AM | #11 |
That's the 1st experiment of Por 15..............
1997 GMC Sierra Ext 1965 Mustang |
11-13-2007, 11:09 AM | #12 |
Happy to be here
11-13-2007, 10:47 PM | #13 |
.... The theory behind whose ever bright idea that was is ****ed up like a football bat.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
11-13-2007, 11:12 PM | #14 |
Self-proclaimed LED man
looks like roofing tar to me!!!
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once Norwood Survivor |
11-13-2007, 11:26 PM | #15 |
Designated A-hole!
Run don't walk away from that one.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
11-13-2007, 11:38 PM | #16 |
Eww. That looks just like Duraglass (fiberglass reinforced body filler).
11-13-2007, 11:57 PM | #17 |
unless your looking at it for other parts i sure wouldn't buy it for a builder unless you already have a cab. i would much rather spend a little more and start with a soliad cab. it will cost less and you will end up with a better truck done faster
common sense isn't so common anymore |
11-14-2007, 12:38 AM | #18 |
I'm already on the flipside.
That looks like tar to me. I once owned a CJ7 that had the whole underside coated with tar and it looked exactly like that. Major pain to get off!
11-14-2007, 02:01 AM | #19 |
yeah be very weary i bought my 68 that looked like that and turned out to be all filler and very little metal undernieth....i would look into it closer...in my case i wish i were on the forum to ask this type of question before i delved into the project that is my cab rust repair....not difficult but a lot more time and mney than i had accounted for...just a heads up....good luck
11-18-2007, 09:12 PM | #20 |
Update - she made it to ebay - strangely enough - the pix of the undercoating didn't make the auction -
I asked repeatedly to see the metal of the floor pans and he kept saying that it seemed like the rubber mat was 'glued' to the truck and he didn't want to rip it... I guess the rivets for the 'body work' should be the key to look out for... Here is the auction: ebay auction #330189270286 He was asking 1200 on CL... The guy was nice enough to take the pictures of what I asked to see (other than the floor pans)...so take that for what it is worth. |
11-18-2007, 09:41 PM | #21 |
In the auction he stated the floor was solid......
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-18-2007, 10:01 PM | #22 |
he told me that as well - just couldn't show me the proof - so I walked away...
oh well...guess we will see what happens... |
11-19-2007, 08:16 AM | #23 |
The whole truck looks like a patched up bondo buggy... There are many much nice trucks out there for a little more coin.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
11-19-2007, 10:17 AM | #24 |
If its a good enough deal, replace the floor with a goodmark peice, it will take care of all the weird issues.
67- 72 Parts collecter |
11-19-2007, 12:05 PM | #25 |
floor pan and rocker panels are very easy and straight forward to replace, i assume that thats bondo but if the rest of the truck is solid and cheap you can fix all that for about 50 bucks and one days work, how ever if the floor is that bad then the kick panel and lower door pillar is more than likley shot too still though its an easy fix, i replaced kick pannel, floor pan, inner outer rocker,cab support and rocker and lower door pillar all in one day and it was the first time i done sheet metal work, i must say it looks professional except for my hand made floor panel but hay aslong as its solid metal its just getting covered with carpet and undercoating any how im not going to sema or anything one thing about it there aint no rust....
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS Last edited by Robznob11; 11-19-2007 at 12:06 PM. |
