Old 11-12-2007, 10:40 PM   #1
Ace in the hole
serpentine belt question
I might be able to pick up a good deal on a new chevy performance parts serpentine belt system, complete- new, never used, but I am wondering if it will bolt up to my old 1970 350 motor? any issues I might run into?
new performance part # 12497697 complete serpentine drive w/o AC
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 11-12-2007, 10:57 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: serpentine belt question
You'll need a reverse rotation water pump, which will stick your fan out a little further. IIRC, a 2 wheel drive fan shroud will be far enough forward that you can place the fan correctly in/out of it.
Old 11-12-2007, 11:02 PM   #3
Ace in the hole
thanks for the info. I'll be using an electric fan so that should not matter to me but good to know.
the new "serpentine drive" listed above comes with:
new reverse water pump
new alternater
new power steering pump
a/c delete pully
mounting brackets, drive pulleys, hardware & tensioner & belt
Old 11-13-2007, 06:12 AM   #4
Ace in the hole
anybody know if this will bolt right up or if there are any issues?
Old 11-13-2007, 11:31 AM   #5
kwmech
If the kit is complete there should not be any issues. Got one for my 69 GMC--had everything I needed and more.
Old 11-13-2007, 02:23 PM   #6
Ace in the hole
cool, thanks
