11-13-2007, 12:53 PM | #1 |
resident wrencher
dans 60
does any know where or how much a good dana 60 would be and how much work would it be to install onto a 66 k20 lwb fleet
11-13-2007, 01:21 PM | #2 |
Re: dans 60
Front or rear diff? If front,be prepared to spend near $1000 in most cases for one.It should just bolt in,then you have to adress steering,brakes,etc.
11-13-2007, 04:03 PM | #3 |
resident wrencher
Re: dans 60
it a rear
11-13-2007, 09:21 PM | #4 |
Hollister, CA.
Re: dans 60
Installing is not too big of a deal...you just need to cut and weld.
Click on the 2nd link in my sig...and go to post #100 Give you an easy way of doing it.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
11-13-2007, 11:37 PM | #5 |
Re: dans 60
Should be right around $100 bucks or so, have you thought of using a Corporate 14 bolt full floater? Supposedly stronger, GM original equipment, and again, around $100 on craigslist or pirate4x4.com
11-14-2007, 09:09 AM | #6 |
Hollister, CA.
Re: dans 60
Thats what's use on my build...PreRunner, what's up man ??
Haven't seen you on here for a while ?? The people on Pirate suck....not as friendly or helpfull as on here I've noticed. I go their a little for my ZUK build. Later
11-14-2007, 10:16 AM | #7 | |
Re: dans 60
The people on pirate do suck for the most part, all of them have built the most bad ass wheeler from their computer, but never fabricated anything themselves. I'm doing a solid axle/4wd swap on my 2001 2wd Silverado, and all I heard from alot of people on their was no way, not possible. A few chimed in that actually had done it, and gave me plenty of helpful advise to think about. That being said, if you want to wade through the bs over there, there are some great people who are very knowledgable! |
11-14-2007, 12:08 PM | #8 |
resident wrencher
Re: dans 60
i dont really want to cut or weld if i have to i could
11-14-2007, 01:53 PM | #9 |
resident wrencher
Re: dans 60
hey i just found a dana 60 from a 66 k20 for 360 at a local junkyard and on craigs list i found a 14 8 lug for 250 with 410 gears which is better
11-14-2007, 11:49 PM | #10 |
60-66 Nut
Re: dans 60
Probably the most important is getting one that has the proper gearing to match your front diff. As for which one is better a 60 or a 14 bolt FF, it partly depends on your intended use. The 14 bolt FF may be a little stronger IMO, and parts availability for either is good. One thing to consider is I believe the average 14 bolt FF is going to have a 1 1/2"wider track width than that '66 D60. The exception to that is a 14 bolt FF that came in a 1 ton cab and chassis, which will be narrower than a regular pickup differential. If you do go with a 14 bolt be sure to go with a full floater (FF), not a semi floater (SF).
If it were me I would go with the 14 bolt for the price difference providing it meets your needs as stated above.
11-15-2007, 06:15 PM | #11 |
resident wrencher
Re: dans 60
what if neither match my front diff geraing
11-15-2007, 06:15 PM | #12 |
resident wrencher
Re: dans 60
i mean im getting new gears any way
11-16-2007, 12:04 AM | #13 |
60-66 Nut
Re: dans 60
Well since you're going to go with new gears, the 14 bolt makes more sense from a cost standpoint. But that is provided it fits your need as I stated above....the wider track width mainly. A couple of other things come to mind regarding the 14 bolt (1) shock mounts on the 14 bolt will be staggered, IIRC your '66's aren't (2) you may want to check the width on the spring perches, I'm thinking they are the same but I'm not positive. On the plus side the 14 bolt is going to have bigger brakes than that D60 you found.
