11-14-2007, 01:20 PM | #1 | |
FarmBoy.
307 hissy fit?
hey all.
my 307, which ran very reliable, albight rich, decided it doesn't want to run anymore. First issue. it'll run when i'm cranking - that is, it'll fire, but as soon as i get off the eky, it dies. second - the wiring along the top of the firewal started to smoke. i traced it to a wire splice that wasn't coated - i think. third - i sprayed some cabr cleaner down the hatch, along with working the throttle to see if there were streams of fuel going in (there was), and tried cranking over. there was a loud *POP*, and then it would just crank. so..back fire. i dunno what the issue is. i'm thinking maybe my plugs and wires are shot? any insight would be helpful, so..yeah,. thanks in advance! i appreciate it. -Sam,
1969 GMC C1500. long fleet. 307. 3 on the tree. 3.07 gears. Oliver green. Bent and bruised. Daily Driver. Quote:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993 |
11-14-2007, 01:51 PM | #2 |
Re: 307 hissy fit?
if it ran rich for awhile - the plugs could very likely be fouled -- but they will still usually start unless they are really crusted over ---- hmmm
11-14-2007, 01:57 PM | #3 |
Re: 307 hissy fit?
Check if you have power to the coil with ignition on run position. Maybe your coil is only getting power while in crank????
11-14-2007, 01:59 PM | #4 |
Re: 307 hissy fit?
Loud pop=backfire; could = jumped timing?
Keith 70 CST longbed in progress. Hoping to get it back on the road soon. |
11-14-2007, 02:02 PM | #5 |
Re: 307 hissy fit?
fuel - check
spark - check? timing - SHOULDN'T change on it's own but check - loose dizzy? Check the wiring from the back of the ignition, out... Then I'd check your dist - if points, clean - if HEI - verify 12v.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
11-14-2007, 03:27 PM | #6 |
Re: 307 hissy fit?
Since you had things apart, I'd double check the timing. Dist may be off a bit.
Also, you had the cab off, so check your grounds. Make sure you got them all hooked back up.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 11-14-2007 at 03:29 PM. |
11-14-2007, 03:35 PM | #7 |
Re: 307 hissy fit?
check the ballast resistor/ignition supply wire & coil. Condensers going bad in points ignitions can cause symptoms similar to yours as well. Good hunting.
Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
11-14-2007, 03:53 PM | #8 |
I have a radical idea!
Re: 307 hissy fit?
If you washed down the truck before you painted it with the front clip off, you could have got water in the distributor also. I'd pop the cap and check for moisture/corrosion. It's also FREE to do that!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 11-14-2007 at 03:53 PM. |
11-14-2007, 05:15 PM | #9 |
Re: 307 hissy fit?
my 307 always ran rich and finally burned my vavles mine starts but backfires all the time
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
11-14-2007, 09:29 PM | #10 | |
FarmBoy.
Re: 307 hissy fit?
found the problem!
one of the wires on the starter was touching a header tube. apparently, it was the "run" circuit of the ignition, where as the "start" circuit was still functional, hense...it running while the engine was cranking over. i was at school when i posted that, and it was driving me nuts. little did i know, my dad read the note i left him when he came home for lunch, and had already diagnosed them problem, lol. so, yup. she runs like a top still. just have to get a manual conversion for the choke, and pick up my wire loom tomorrow, and she *should* be good. thanks for all the advice guys! you really hit on just about every possibility. i appreciate it greatly! -Sam.
