11-14-2007, 02:23 PM | #1 |
Sofa King. We, Todd, Ed.
Broken front drive shaft CV
Whats the best solution for this. Its the second time I have broken the center part of the "CV" on my front driveline. Im talking about the assembly at the transfer case for the front driveline. The U-joints still look OK. Can the "CV" be eliminated? Is it even called a "CV"? Im sure someone makes something better. Thanks.
11-14-2007, 04:52 PM | #2 |
Re: Broken front drive shaft CV
It is really called Double Cardan Joint. They are not typically a problem. How have you broken it? Do you have a lift? Is the slip joint in the front shaft in good condition?
Tim |
11-14-2007, 07:49 PM | #3 |
Typically these are broken because of binding, either from too much lift or droop when 'wheeling.
11-15-2007, 06:02 AM | #4 |
Never broke one but upgraded to a 1 ton front shaft last year when I needed another front drive line due to the existing one didn't have a long enough slip in it...guess how I found out.
Surprised to hear your breaking the front shaft that way though, must be all that Spokane sand or something. |
11-15-2007, 10:06 AM | #5 |
I too have never broke that part of my driveline. But I did upgrade my drivelines, got them from HighAngle Driveline here in Cali. I would take a measurement from pinion yoke to T-case yoke and have one made and get the beefest one you can afford with the CV
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks Last edited by Burt4x4; 11-15-2007 at 10:09 AM. |
11-15-2007, 10:57 AM | #6 |
Never seen one break.It`s strange that a u-joint took what that yoke couldn`t.Let`s see the damage.
11-15-2007, 12:37 PM | #7 |
Yeah its weird. I hope its just "one of those things". I'm going to rebuild it with regular parts for now. I'll tear it down tonight and post some carnage pix tommorrow.
11-16-2007, 12:19 AM | #8 |
They strarted using the dbl cadon joint when they "married" the trans and t-case which shortened the front driveshaft.The purpose is they handle a steeper angle.Guys are adding a second one on the other end of the front shaft and on rear shafts when lifting alot,on shorter rigs,and when going with doublers(rear shaft).
11-16-2007, 05:35 AM | #9 | |
Rear shaft joint pictured. |
11-16-2007, 01:09 PM | #10 |
The weld-on yoke (to the driveshaft) failed and took the centering yoke with it. On the picture of the new parts the arrow points to the "cup & pin" on the weld-on yoke that connects to the "ball" on the centering yoke. This is where something went wrong. Hopefully it was just old and fatigued. Both u-joints are perfect and the outside case yoke doesn't have any binding/impact marks.
11-16-2007, 04:56 PM | #11 |
I would guess that someone put new u-joints in and did not replace the rest of the worn out parts. That probably led to your failure.
Tim |
11-16-2007, 06:16 PM | #12 |
I did put new HD u-joints in not long ago but seriously...who is going to cut off the driveline welded yoke and replace it if its not broke?
11-22-2007, 06:05 PM | #13 |
The driveline's all better now....my wallet is NOT.
11-22-2007, 07:27 PM | #14 |
