1970 Daily Driver
T-Arm Crossmember Pipe Size
Now that I have dropped my truck I would like to re-run my exhaust up higher. My question is when I go through the t-arm cross member can I use 4 1/2" outside diameter pipe, which I have, or is that too big? What sizes have you guys used? Here is a picture from the faq page of what I am talking about.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
Dave's not here, man
Re: T-Arm Crossmember Pipe Size
I don't see why that wouldn't work. The crossmember that Early Classic sells allows for 3" exhaust to pass through, so I would imagine that the holes are at least 4" wide. Don't see what another 1/2" would hurt. I'm sure someone else will chime in with more info.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
