Old 11-14-2007, 04:50 PM   #1
Green Monster
Green Monster's Avatar
Fuse Panel
I got my wiring a little mixed up on my fuse panel. Does anyone have a diagram of where wires are supposed to go on the fuse panel on a 72 Blazer? I'm just talking about the ones that you plug into the fuse panel. I need my gas gauge and radio to work properly along with my distributer. I can't seem to get these right. I managed to drain and kill a brand new battery in a month because I had the wires hooked up wrong. The battery won't even take a charge and has 0 volts. That's how dead it is.
Green Monster is offline   Reply With Quote
Old 11-14-2007, 06:04 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Fuse Panel
I could try to take pic of mine, if that helps. Don't know if it was ever fooled with. I have a factory wire diagram as well if it helps... or you stop up and look for yourself. J.
BTW... I have a Jimmy, you have a Blazer, they could be different
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-14-2007, 07:50 PM   #3
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: Fuse Panel
There's a pic of the fuse box with it all labeled on the board here. I'm trying to find it, if I can I'll post a link.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 11-14-2007, 07:55 PM   #4
red71cheyenne
Back in the sticks
Re: Fuse Panel
Look at this one...
http://67-72chevytrucks.com/vboard/s...d.php?t=121515
2011 K1500 Suburban
2014 K1500 Pickup
Old 11-14-2007, 08:18 PM   #5
Green Monster
Re: Fuse Panel
Thanks for the link red cheyenne. I have added that image to my archives. That was exactly what I needed.
Jaros: I'll have to take you up on that offer when the weather is decent. It would be nice to get together to check out your Jimmy.
I took by battery to Pep Boys and they charged it up for me. Apparently my charger is too weak to charge a dead battery. ??? It puts out 6 amps.
Old 11-14-2007, 09:05 PM   #6
jaros44sr
jaros44sr's Avatar
Re: Fuse Panel
Do you think this current condition might be traced back to the other condition you had a month ago, some voltage draw from an unknown source...
Your welcome to come up anytime, the Jimmy is hermetically sealed in a 70 degree chamber
SAFETY FIRST
AS usual, off topic
Jim
Old 11-15-2007, 03:12 PM   #7
Green Monster
Re: Fuse Panel
This condition is from me tinkering around and changing wires around. I have a bunch of wires coming out of this thing.
