Old 10-08-2002, 06:00 PM   #1
meathead95
computer illiterate
meathead95's Avatar
1406 question
which vaccume port do you use for your timing the one on the driver side or the one on the passenger side
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 10-08-2002, 06:37 PM   #2
71402BB
now thats a true COON DOG
as far as I know you can use either or. I use the passenger side because it's the closest....
current project
67 402BB stout th350 3.08's with a locker. Plan on tubs 18.5's out back! (thanks Burnsman!)
71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) was my first truck!... oh well...
72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!)
68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!)
67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!)
71402BB is offline   Reply With Quote
Old 10-08-2002, 06:51 PM   #3
crazy longhorn
Fabricate till you "puke"
I use the dr side(full manifold), the pass side is ported spark......you might try em both & see what works best for you. generally, if running a stock, or mild cam,& leaner carb ported spark works good......hot cams & fat carbs tend to like full manifold for the vac timing. good luck.....crazy man
crazy longhorn is offline   Reply With Quote
