Old 11-14-2007, 08:06 PM   #1
tx71smallblock
tx71smallblock's Avatar
carb dual fuel feed
would a dual fuel feed on a carb make it run too fast?
as in getting to much fuel?
70 Chevy C-10 short step
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
tx71smallblock is offline   Reply With Quote
Old 11-14-2007, 08:27 PM   #2
cdowns
cdowns's Avatar
Re: carb dual fuel feed
not if your pressure regulator is set and working properly/and your floats are set to specs
Old 11-14-2007, 08:45 PM   #3
tx71smallblock
its just an edelbrock 650, no regulator i dont think. but i put a duel feed set up on it cause it looks good and now its ideling at 1000 with the idel screw backed all the way out
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 11-14-2007, 09:06 PM   #4
cdowns
cdowns's Avatar
never heard of a dual feed edelbrock carb would like to see pictures
Old 11-14-2007, 09:22 PM   #5
tx71smallblock
here u go...
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 11-23-2007, 01:26 AM   #6
wzuke
wzuke's Avatar
Make sure your choke is set and working correctly.
wzuke is offline   Reply With Quote
Old 11-23-2007, 01:51 AM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Ok thats the 1st time I have ever seen that ....... Glad you had a pic cause I would have called b.s. on that ??
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-23-2007, 02:36 AM   #8
RyanG
RyanG's Avatar
Not sure if this will help but I had the same problem.....I checked the timing and I was at like 16 deg BTDC.....I fixed that and all of a sudden I had full opertion of the idle screw. I am not sure why it worked like that but it did. Maybe the gremlins climbed out when I walked away from it. J/K
Just a thought.
RyanG is offline   Reply With Quote
Old 11-23-2007, 06:52 PM   #9
tx71smallblock
i noticed that to but when i fixed it it wont start back up afterward.
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 11-23-2007, 06:53 PM   #10
tx71smallblock
so i put it back the way it was (16* btdc)
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 11-23-2007, 07:05 PM   #11
tx71smallblock
i also didnt know the choke controled anything after start up. mine is elec. but not hooked up will that help with the fast idel and not starting when properly timed?
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 11-23-2007, 10:36 PM   #12
TravisH
TravisH's Avatar
I'm no carb expert but the edelbrock isn't 'dual feed' like a holley, its meant to be set up one side or the other, theres just two ports to make plumbing easier.
Whether that has anything to do with your problem I can't say. The pressure should be the same just more volume
TravisH is offline   Reply With Quote
Old 11-23-2007, 10:47 PM   #13
tx71smallblock
travisH, its not acually being feed from two full sources, its fed from one line into a spliter that directs the fuel to both sides
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 11-24-2007, 12:23 AM   #14
scooter122983
The Man The Myth The Mystery
Make sute the choke is wired to a full 12 volt source because if it is not getting the proper voltage then it will run at fast idle with the choke closed.
scooter122983 is offline   Reply With Quote
Old 11-24-2007, 12:55 AM   #15
tx71smallblock
where is a good place to wire it?
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 11-24-2007, 01:12 AM   #16
berencam
berencam's Avatar
you can run it with the same wire that runs your hei dizzy....
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 11-24-2007, 01:24 AM   #17
tx71smallblock
so the wire that runs power to the dist. cap marked "batt" or "battery" is a good place.
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 11-24-2007, 01:25 AM   #18
berencam
berencam's Avatar
mmm i think that isnt a ignition only wire.... that being said im not the one to be asking on the wiring. But i do know it needs to be a ignition only wire not always on.
Old 11-24-2007, 01:33 AM   #19
tx71smallblock
what did u mean by "the wire that runs your hei dizzy" ?
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 11-24-2007, 01:34 AM   #20
berencam
berencam's Avatar
the positive one that is hot when you turn the key to on...
Old 11-24-2007, 01:37 AM   #21
tx71smallblock
so like the ones i used to give my tach and radio power?
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 11-24-2007, 01:39 AM   #22
Billla
Billla's Avatar
I think there's something's fundamentally wrong here; I doubt the carb is dual feed; it's set up to feed from one side OR the other. If this is the ONLY change you made that caused the problem, then I wouldn't look elsewhere - I'd swap it back and see if it goes away.
Billla is offline   Reply With Quote
Old 11-24-2007, 01:40 AM   #23
berencam
berencam's Avatar
yes, but i would like someone else to chime in, i would hate to ruin your electric carb.
Old 11-24-2007, 01:44 AM   #24
tx71smallblock
the dual feed kit is an edelbrock product, its made for that carb. i did take it off the other day and run a single line the carb but it still ran at exactly the same rpm.
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 11-24-2007, 01:52 AM   #25
Billla
Billla's Avatar
Learn something new every day
So - did this problem start suddenly or it's always been there? Anything else change when it started? Did it happen suddenly or over time? The key questions are what changed and when...
