11-14-2007, 11:22 PM | #1 |
Trying to get fender off,HELP!!
Alright, I am trying to get the passenger fender off my 67 c-10, I have take most the bolts out the bottom just a few stubborn ones left and I have drilled all the spot welds out which I am starting to think I didn't have to do, Please tell me you are suppose to, I got the front grill off and the motor out, the cowl is removed and so is the hood and hinge, I got the screws out and am wondering what I may have left??
1967 c-10 longbox project, check it out in projects 1969 c-10 parts pickup, twisted frame Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block |
11-14-2007, 11:28 PM | #2 |
Re: Trying to get fender off,HELP!!
sorry but i you dont need to drill any welds
there are bolts on from the core support (top and bottom), inner fenders. side of firewall under cowl cover, grill, and fron under the truck the is a bolt or two at the bottom of the door piller. am i missing any spots?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB Last edited by cstm68; 11-14-2007 at 11:29 PM. |
11-14-2007, 11:30 PM | #3 |
Roadtrip!
Shouldn't be any spot welds to drill. Did you get around the inner wheel well? Should be a few where the grill would be going into the side. A couple behind where the cowl panel is. A bigger one underneath by the door. Hope this helps.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
11-14-2007, 11:31 PM | #4 |
On my 72 there were no spot welds to drill out. There are I think 4 bolts that hold the front of the fender to the rad support. A few that hold the bottom of the front fender well to the bottom of the rad support if taking off the fender well and fender as a unit. The bolts that hold the fender to the fender well. One bolt on the bottom of the fender that bolts it to the cab. 2 bolts that are bolted to the top of fender under the cowling. If your taking the fender well out there is also one bolt under the fender well that bolts it to the cab.
11-15-2007, 01:27 AM | #5 |
Lemme show you something!!
Exactly what "Dastuck" said, except my '67 has a bolt from the inner fender to the battery tray as well.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
11-15-2007, 04:02 PM | #6 |
thanks for the info I got it off, good thing it wasn't salvageable because I went and drilled out all the spot welds that hold the shell on the inner part
