Old 11-15-2007, 01:31 AM   #1
Ackattack
Ackattack's Avatar
couple of airbag questions
I started installing my bags this weekend and ran into a few questions.
I'm using RE7s and plates and cups from suicide doors. Stock control arms.
First, on the front, the cup is not fully seating into the lower control arm. It's calked in there at an angle. Granted, there isn't a lot of weight to force it all the way down in there, but I wouldn't think there would need to be. I could cut them, but I'm not sure if this will help anything besides getting a little lower.
Next, I cut off the lower control arm bumpstop since the RE7s have internal bumpstops. But I kind forgot that those are also the steering stops. Do I need to weld those back on?
Now to the rear.
How are you guys positioning your bags? The fitting isn't in the best spot. I notched a little bit of one of the cross members for clearance, but this makes the upper and lower plate off set a little from each other in order not to be on the frame. Any suggestions would be great.
Ackattack is offline   Reply With Quote
Old 11-15-2007, 03:56 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: couple of airbag questions
Up front, they will 'rock' a little unless you trim them to fit the spring cup. I cut mine even with no problems- with some weight they won't move- I would go ahead and cut them down to 1.5" as well.
In the rear, most end up with the fitting inside the framerail- PITA to get to, but eliminates alignment problems.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-15-2007, 02:30 PM   #3
pissonNOS
senior member
pissonNOS's Avatar
put mine in the frame rail, not too worried abiout them being a PITA hopefully i dont have to take them out too often (cross fingers)
69 GMC bagged
pissonNOS is offline   Reply With Quote
