Old 11-15-2007, 11:34 AM   #1
abadsvt
abadsvt's Avatar
What size exhaust are you guys runnin?
I am making provisions in my frame for the exhaust and was curious on what size exhaust tube you guys are runnin. I was debating between 2 1/2 and 3". I would prefer 2 1/2 exhaust because i would be able to bend it myself but wasn't sure if 2 1/2 is too small. I am using a LS1 motor with a few upgraded extras and possibly twin turbos if i can afford them. Thanks for the help. Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 11-15-2007, 12:35 PM   #2
SactoJim
SactoJim's Avatar
Re: What size exhaust are you guys runnin?
I've been pondering the same question.
I found this online and copied....
Basically, as a rule of thumb, if your intended use is strictly street, for cruising and maybe as an everyday driver, then 2.5" will be adequate,,,,,,,,,, unless you have 500 HP or more! For the strip, if you have a power plant rated around 425 or more realistic horsepower, then the 3" system would be the way to go. Powerplants with few horses just will not benefit from the larger 3" exhaust although 3" tailpipes showing from behind the rear wheel or under the bumper will make quite an impression. It's been our experience that too big a system will not hurt performance (as long as the primary tubes on the headers are not too large -- Headers do the main 'tuning' of the exhaust), just cost a little more. Now, how about 3.5"? This Huge size is reserved for the really serious,,,,,,, say 600 horses or more!
If you're not sure of the horsepower rating of your powerplant, but have raced at the dragstrip, then any 1/4 mile ET's in the 12.40 - 12.70 range or quicker would benefit from the larger 3" exhaust versus a good 2.5" mandrel bent system.
With powerplants in this horsepower range or up to 575, with a 3" system, you will be able to basically turn ET's equivalent to those with open headers. Imagine! Running through the exhaust and turning low 11's while your competitor is struggling with all the noise and just trying to keep up.
Most 525 HP or so powerplants will never know the difference between 2.5" or 3" on the street for daily driving or cruising, although the big 3" "sewer Pipe" will certainly look great!
Now, IF you're in the 575 HP area, the Big 3.5" pipes might be your ticket. These are some really HUGE pipes and we've had reports of guys loosing their arms in them....just kidding!
The Following Tech Tips are courtesy of the Dynomax Division of Walker/Tenneco web site. This info can be found here at www.dynomax.com/techsupport.stm.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 11-15-2007, 01:50 PM   #3
chevy72blu
chevy72blu's Avatar
for a mild to moderate LS1... I'd go 2.5. In my experience, LS1's actually like a little backpressure. Most modern engines seem to be designed this way.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 11-16-2007, 12:50 AM   #4
69heavychevy
69heavychevy's Avatar
well if you do decide to run turbos, remember that less backpressure=more efficient turbo.
69heavychevy is offline   Reply With Quote
Old 11-16-2007, 07:14 AM   #5
jim zag
ENGINE BUILDER
jim zag's Avatar
I use 2.5 inch because it is easier to fabricate out of easy to get pieces. I also have noticed that cars with 3 inch exhaust have a much louder sound and interior noise level. I drive my truck as much as possible and do not like a lot of noise! If you can bend your own pipes you are much better off!
BUILD IT TO DRIVE!
JIM ZAG
jim zag is offline   Reply With Quote
Old 11-16-2007, 08:53 AM   #6
1970cstblazer
1970cstblazer's Avatar
Thumbs up Re: What size exhaust are you guys runnin?
The truck has dual 2.5" pipes.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 11-16-2007, 09:35 AM   #7
orange72c10
The articles that I have read say in order to run 3 inch you need to have a lot of hp to make it worth the extra money. I would say to run 2.5 inch for your set up. I have 2.5 inch with flowmasters and am very happy.
orange72c10 is offline   Reply With Quote
Old 11-16-2007, 11:19 AM   #8
abadsvt
abadsvt's Avatar
Thanks for the help guys!!!! I guess i need to figure out if i am going to run the turbos or not. Also what mufflers do you guys recommend. I was hoping for those long skinny ones since i only have about 7" in width to fit the mufflers. Thanks again.
Josh
(Project truck)
Old 11-16-2007, 01:42 PM   #9
SCOTI
SCOTI's Avatar
An LS1 would work well w/a mandrel 2.5" exhaust using an 'X' style crossover tube for better scavenging (sp?). You could also do a 3" system from the collectors to the muffler inlets but use 2.5" for outlets/tail-pipes. Regardless... use a crossover if power is important.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-16-2007, 01:50 PM   #10
space
2.5 with 40 series.
space is offline   Reply With Quote
Old 11-16-2007, 01:55 PM   #11
jkade
jkade's Avatar
ls1, mac mids, 2.5" and h-pipe
jkade is offline   Reply With Quote
Old 11-16-2007, 02:50 PM   #12
chev74
Addicted to Chevy
chev74's Avatar
do the 2.5" with flows. I reccommend the new Super 44s or the original 40 series. They sound the best. Classic tone, deep sound. The long skinny ones you speak of- do you mean glass packs? or the racing mufflers?
chev74 is offline   Reply With Quote
Old 11-17-2007, 11:02 AM   #13
abadsvt
abadsvt's Avatar
I was hoping to use something like these. http://www.magnaflow.com/02product/s...ne=main&id=351 . When i designed all the internal bracing in my frame i got a little carried away so there isn't too much room. In a few days i will have some pics to help everyone understand. I hope these round ones still sound good. Thanks Josh
(Project truck)
Old 11-17-2007, 11:16 AM   #14
chev74
Addicted to Chevy
chev74's Avatar
go for it, I have heard lots of guys like the magnaflows. I personally have never heard them in front of me, only sound clips, and they never do justice. I am SURE they will sound great
Old 11-17-2007, 12:28 PM   #15
Ackattack
Ackattack's Avatar
I have 2.5" dual with X pipe in my corvette (LS1) and it seems to do well. It's making about 350RWHP.
My 72 GMC (TPI 350) has 2.5" duals (no X pipe) that is not mandrel bent.
For my 68 Chevy, I'll be running 3" mandrel bent. I'm hoping for 400RWHP. It's going to be a bracket racer/show truck so noise level isn't a big concern.
Oh, and just for reference the LS1 F-bodies run a 3" single pipe back to the muffler, and they're doing fine, so 2.5" duals should be sufficient for most applications.
Ackattack is offline   Reply With Quote
Old 11-17-2007, 04:29 PM   #16
abadsvt
abadsvt's Avatar
Do you guys think i will need an "X" pipe?
(Project truck)
Old 11-17-2007, 05:06 PM   #17
bad6772
Official Site Guitar Shredder
bad6772's Avatar
when mine was together i ran 3 inch from the manifolds to a cross over then 3 inch to the mufflers( flowmaster 40 series) then 2.5 for about a foot and then a turn down...
bad6772 is offline   Reply With Quote
Old 11-17-2007, 05:09 PM   #18
Ackattack
Ackattack's Avatar
an X pipe will help make more power. It will also help to tone the noise down a little too.
Old 11-17-2007, 05:11 PM   #19
bad6772
bad6772's Avatar
i meant a x pipe sorry
Old 11-17-2007, 06:19 PM   #20
corn
2 1/2 will be perfect. Plenty really. The X pipe will improve low end torque & quiet the low RPM tone too. I dont run them though...
corn is offline   Reply With Quote
Old 11-17-2007, 06:35 PM   #21
abadsvt
abadsvt's Avatar
Thanks everyone! I am not quite ready to install the exhaust but now i have a game plan!
Josh
(Project truck)
Old 11-17-2007, 06:47 PM   #22
jkade
jkade's Avatar
You will like them, they sound like nothing I have ever heard. I have them on my 67 with the ls1 and I will also put a set on my blazer with the 6.0 If I knew how to make a good quality sound clip I would. You can't go wrong with them and summit had the best price at the time.
Old 11-17-2007, 06:49 PM   #23
Slammed70
Slammed70's Avatar
In my Camaro....I ran Kooks headers with a 3.5in primary, into a Mufflex 4in Y-pipe and 4in through to the back where there was a Dynomax Bullet muffler, then Y'd off into dual 3in over the axle and out the back.
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 11-17-2007, 07:55 PM   #24
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
I made the decision to run full headers even though I had to raise the truck for clearance.
I also made the decision to run full 3 inch headers and full 3 inch straight out the back with 3 inch flowmasters and crossover tube.
If you have ever stood behind a full 3" dual exhaust and listened to it idle and run hard you will know exactly why some of us spend the extra $$. NOTHING else sounds like it.
So what you need and what you want can be two very different things It all depends on you and what you want from your truck.
Good luck with your decisions.
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 11-17-2007, 08:33 PM   #25
Mondo
Mondo's Avatar
A single 3in will flow the same as dual 21/2in. I think it sounds better too (smoother).... just don't use a flowmaster unless you like your sound loud, low, and with truck vibrations thrown in (experience).
Windancer, they must hear you coming for miles
Mondo is offline   Reply With Quote
